Compilation error when using boost Bessel function in OpenFOAM
I am trying to make a custom solver based on pimpleFoam, which includes a Bessel function in an equation which I added in the PIMPLE-loop. In the beginning of the solver, I have an include-statement which I believe I need to use the Bessel-function from boost: Code:
#include <boost/math/special_functions/bessel.hpp> Code:
usr/include/boost/math/special_functions/detail/bernoulli_details.hpp: In function ‘std::size_t boost::math::detail::find_bernoulli_overflow_limit(const false_type&)’: Code:
/opt/openfoam10/src/OpenFOAM/lnInclude/dimensionedScalar.H:65:19: note: candidate: ‘Foam::dimensionedScalar Foam::sqrt(const dimensionedScalar&)’ What could I do to solve this problem? If I include other boost library functions, for example "elliptic integral" from the "special functions" directory, then it compiles without error. So the error seems localized to bessel. And it seems the compiler is complaining about "sqrt( )" somehow (which I didn't type in or add anywhere, must come from boost). Very strange! I'm thankful for any tips/suggestions you may have. |
