buoyantFoam problem with meshToMesh
Hi everyone, I'm trying to make a simulation of a moving inflow, it should simulate the wearing out of an electrode. The Openfoam version is OF.org V10.
In this process I used dynamicMeshDict to make the mesh move, when the deformation of the mesh was no longer acceptable I wanted to do a meshToMesh. In this step I have an error: Code:
FOAM FATAL ERROR: Searching online I found that this problem was present in XiFoam as "XiFoam: Removed redundant rhoEqn solution after mesh topology change". The git hash is 7dd5c4d3fac0704492a5b81f3315abe7d3443a6f . I tried to look for some redundancy in this case too but I couldn't find anything. Does anyone know this error or how to fix it ? |
can anyone help me?
At the moment I think the error occurs in this area of the code:
autoPtr<volVectorField> rhoU; All fields are printed correctly (even V0). It makes me think something is going on with directories. |
it seems that the error is generated from this point, we are in fvMeshGeometry.C.
const Foam::volScalarField::Internal& Foam::fvMesh::V0() const |
