How can the largest eigenvalues be obtained from a PCG loop? |
Klaus
Rep Power: 23 ![]() |
The paper "AN OPTIMIZED CHEBYSHEV SMOOTHER IN GAMG SOLVER OF OPENFOAM ON SUNWAY TAIHULIGHT SUPERCOMPUTER" states, that "...the PCG loops are used to obtain the largest eigenvalues since it has same upper bound as for the Chebyshev iteration in the symmetric case...".
How can the largest eigenvalues be obtained from a PCG loop? Link to the paper: https://dcwan.sjtu.edu.cn/OpenFOAM20...W13-25-133.pdf |
Apologies for spotting this month too late.
The CG algorithm can be instructed to compute the Ritz values. These Ritz values approximate the eigenvalues of the matrix. This is known as the Lanczos algorithm, see https://en.wikipedia.org/wiki/Lanczos_algorithm. See also the books the Youssef Saad. |
Display Modes | |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM Running, Solving & CFD | 15 | October 19, 2015 13:52 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
