overset simulation with abnomal force and motion at beginning
Old   September 19, 2024, 22:25
Default two phase flow overset simulation with abnomal force and motion at beginning
Shen Tsao Hung
santhou is on a distinguished road
Hi all,
I tested a still water case with a floating cylinder and ran the simulation. However, abnormal forces and motions occurred in the z-direction at the beginning. Upon restarting, I suspected this might be due to an unbalanced initial water level. To address this, I tried adjusting the height of the water surface to reduce the initial imbalance, but it didn't seem to solve the problem.
Additionally, I ran another simple test case and noticed that the interpolation between the water surface (alpha=0.5) of the overset and background grids is discontinuous at the overset patch, as shown in the attached figure. I'm not sure how to fix this. Could this discontinuity be the main cause of the issue?
I'm using OpenFOAM version 2312. Could anyone help me figure this out?
Best regards,
Santhou
santhou is offline   Reply With Quote
Old   January 2, 2025, 03:25
Shen Tsao Hung
Hello everyone:
I have found oscillation issues, but as a beginner, I am unable to resolve them. The oscillations stem from the overset mesh's interpolation. While other physical quantities seem to interpolate without major issues, the problem arises with alpha.water. Using the default interpolation methods causes discontinuities in the water surface. This is because the water surface is a discontinuous physical quantity (in terms of analytical solutions, it's either 0 or 1). The interpolation uses nearby points with a weighted least squares approach, which leads to unrealistic interpolation results.
Attachmnet shows the beginning time for alpha.water interpolation and the velocity.
Best regards,
Santhou
Calculation of drag force and yaw moment of catamaran hull CenterRime OpenFOAM Running, Solving & CFD 0 April 10, 2023 00:41
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
2DOF Planning hull resistance study with overset CFD_fan OpenFOAM Running, Solving & CFD 7 July 13, 2021 06:03
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 23:35
udf for one dimensional linear motion based on force maccheese Fluent UDF and Scheme Programming 2 September 1, 2019 03:18
