Problem installing FOAM2CSR
Like Tree1Likes
  • 1 Post By quarkz
Old   November 5, 2024, 05:36
Default Problem installing FOAM2CSR
TWB
quarkz is on a distinguished road
I'm following the instructions here:
https://blog.nextfoam.co.kr/2024/01/...th-petsc4foam/
on how to test OpenFOAM with GPU. I got all the steps working until the installation of FOAM2CSR.
When building, I got the error:
base) user:foam2csr$ sudo ./Allwmake
[sudo] password for user:
./Allwmake: 4: WM_PROJECT_DIR: parameter not set or null
(base) user:foam2csr$
but I already set the dir:
(base) user:foam2csr$ echo $WM_PROJECT_DIR
/home/user/OpenFOAM/OpenFOAM-v2306
Can someone help?
Thanks.
quarkz is offline   Reply With Quote
Old   November 5, 2024, 07:23
Domenico Lahaye
dlahaye is on a distinguished road
I imagine you already did
export CUBROOT=/root/amgx/thrust/dependencies/
export PETSC_INC=/opt/petsc/include
export AMGX_INC=/opt/amgx/include
export SPECTRUM_MPI_HOME=/opt/openmpi-4.0.5
export PETSC_LIB_DIR=/opt/petsc/lib
export AMGX_LIB=/opt/amgx/lib
git clone https://gitlab.hpc.cineca.it/openfoam/foam2csr.git
cd foam2csr
   # Edit NVARCH in the Make/nvcc to your NVARCH
./Allwmake
? Correct?
What files do you have inside the foam2crs directory? Can you compile these files? Can you link these files?
dlahaye is offline   Reply With Quote
Old   November 5, 2024, 09:43
TWB
Hi dlahaye,
Well, almost:
export SPECTRUM_MPI_HOME=/opt/openmpi-5.0.5
export WM_PROJECT_DIR=/home/user/OpenFOAM/OpenFOAM-v2306
sudo ./Allwmake
These are the files inside:
Allwclean  Allwmake  CLA.md  LICENSE  Make  TODO  lnInclude  src
My NVARCH = 86 (A6000)
The error I got when running Allwmake is:
Btw, I'm running under WSL.
Old   November 5, 2024, 17:43
Domenico Lahaye
You say that
Why so? Is the directory OpenFOAM-v2306 (installation) not write protected?
Can you verify using 'ls -l'?
Can you try using
export WM_PROJECT_DIR=~
or similar instead?
Old   November 5, 2024, 20:59
TWB
This is the location which I installed OF, which was done a yr ago. Must OF be in the /opt/ dir?
I run ls -l :
(base) user:cfj_naca2415_c0.3072_5e-5_AoA4_165K_org_2$ ls -l /home/user/OpenFOAM/OpenFOAM-v2306
total 5140
-rwxr-xr-x  1 user user    3392 Jun 28  2023 Allwmake
-rw-r--r--  1 user user    1267 Jun 28  2023 CONTRIBUTORS.md
-rw-r--r--  1 user user   35592 Jun 28  2023 COPYING
drwxr-xr-x  2 user user    4096 Aug 19  2023 META-INFO
-rw-r--r--  1 user user    9473 Jun 28  2023 README.md
drwxr-xr-x  6 user user    4096 Jun 28  2023 applications
drwxr-xr-x  3 user user    4096 Jun 28  2023 bin
drwxr-xr-x  4 user user    4096 Aug 19  2023 build
drwxr-xr-x  4 user user    4096 Jun 28  2023 doc
drwxr-xr-x  8 user user    4096 Oct 31 22:55 etc
-rw-r--r--  1 user user 5154072 Aug 19  2023 log.linux64Gcc114DPInt32Opt
drwxr-xr-x  9 user user    4096 Jun 28  2023 modules
drwxr-xr-x  4 user user    4096 Aug 19  2023 platforms
drwxr-xr-x 47 user user    4096 Jun 28  2023 src
drwxr-xr-x 21 user user    4096 Dec  4  2023 tutorials
drwxr-xr-x  7 user user    4096 Jun 28  2023 wmake
Running:
doesn't make any diff
Old   November 6, 2024, 04:48
Domenico Lahaye
The location of the OF dir does *not* matter here.
What matters is whether you have the rights (priviledges) to write (edit, modify) files in the OF directory.
This is easy to verify.
Can you please do
cd /home/user/OpenFOAM/OpenFOAM-v2306
and subsequently try
touch my_test_file
Once we see the outcome of this small test, we can further elaborate.
Old   November 6, 2024, 20:58
TWB
Yes, I have access to this folder:
-rw-r--r--  1 user user    0 Nov  7 08:57 my_test_file
drwxr-xr-x  8 user user 4.0K Oct 31 22:55 etc
drwxr-xr-x 21 user user 4.0K Dec  4  2023 tutorials
-rw-r--r--  1 user user 5.0M Aug 19  2023 log.linux64Gcc114DPInt32Opt
drwxr-xr-x  4 user user 4.0K Aug 19  2023 platforms
drwxr-xr-x  4 user user 4.0K Aug 19  2023 build
drwxr-xr-x  2 user user 4.0K Aug 19  2023 META-INFO
-rwxr-xr-x  1 user user 3.4K Jun 28  2023 Allwmake
-rw-r--r--  1 user user 1.3K Jun 28  2023 CONTRIBUTORS.md
-rw-r--r--  1 user user  35K Jun 28  2023 COPYING
-rw-r--r--  1 user user 9.3K Jun 28  2023 README.md
drwxr-xr-x  6 user user 4.0K Jun 28  2023 applications
drwxr-xr-x  3 user user 4.0K Jun 28  2023 bin
drwxr-xr-x  4 user user 4.0K Jun 28  2023 doc
drwxr-xr-x  9 user user 4.0K Jun 28  2023 modules
drwxr-xr-x 47 user user 4.0K Jun 28  2023 src
drwxr-xr-x  7 user user 4.0K Jun 28  2023 wmake
This is my own ubuntu so I have sudo rights as well.
Old   November 7, 2024, 06:57
Domenico Lahaye
I see.
I wonder. Is there a difference between
sudo ./Allwmake # with sudo
and
./Allwmake # without sudo
? Also, it there a difference between
sudo echo $WM_PROJECT_DIR # with sudo
and
echo $WM_PROJECT_DIR # without sudo
Old   November 7, 2024, 10:11
TWB
Hi dlahaye, I have solved the problem. It's because I had installed AmgX to restricted folder (/opt/). So I have to use sudo to access it, which is req during the installation of foam2csr. However, it seems tt it's not possible to use sudo with Allwmake.
Once I changed AmgX is a standard installation dir, I just use Allwmake and there's no problem.
dlahaye likes this.
Old   November 7, 2024, 12:14
Domenico Lahaye
Wonderful! Let us know how it goes.
Best, D.
[OpenFOAM.org] Problem in installing OpenFOAM 2.3.0 !!! omid20110 OpenFOAM Installation 6 August 1, 2016 12:20
[swak4Foam] foam-extend-3.2 installing problem: swak4Foam failed to install due to Bison lxwd OpenFOAM Community Contributions 1 March 20, 2016 17:03
Problem with installing OpenFOAM 2.0.X mohsen.boojari OpenFOAM Installation 3 February 3, 2016 12:41
Problem installing OpenFOAM-1.6-ext on Ubuntu 14.04 afrotimy OpenFOAM Installation 4 October 4, 2014 12:36
Problem in installing OpenFOAM-ParaView-0.1.1-1.x86_64 hassan5565 OpenFOAM Installation 1 August 5, 2014 14:05
