heatSource errors respect to physical experiments |
Suhan Umur Okuducu
Rep Power: 2 ![]() |
In OpenFOAM 2406, for a solid cellZone region within the flow domain, I modeled a scalarSemiImplicitSource with h=10W. However, even in a steady-state solution, this source continuously increases the temperature of the solid region. In physical experiments, the temperature of a heat source stabilizes after some time. I do not think there is an error in my reasoning, but I would like to ask whether it is possible to model such a heat source behavior in OpenFOAM.
Rep Power: 14 ![]() |
So, let's think about the physics for a moment. You are pumping in 10W of heat into the solid with a source term - fine so far. This is a suitable and effective approach.
Now - where does the heat go? You say in the experiments that the solid temperature asymptotes after a while, so you must be allowing heat to conduct/convect away from the source and out of the domain. The temperature will stabilise when the heat exiting the domain equals the heat you are pumping in through the source. So my advice is that you check you boundary conditions. Check the fluxes on the boundaries. Are they behaving as you expect? Good luck. |
#3 | |
Suhan Umur Okuducu
Could my problem be that I didn't run the analysis long enough for the endTime? Best Regards |
Display Modes | |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 6, 2023 00:48 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 20:50 |
[Gmsh] Nasa Nozzle: Plot 3D -->gmsh -->fluent - no physical groups | Nico89 | OpenFOAM Meshing & Mesh Conversion | 1 | June 14, 2016 06:40 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
