How to modify field variables using fvOptions
Old   December 24, 2024, 03:21
Default How to modify field variables using fvOptions
Divyaprakash
Divyaprakash is on a distinguished road
I have a few question regarding fvOptions. My question has two parts.
PART 1:
In the following code
codedSource
codeAddSup // source term
 const labelList& cells = this->cells();
vectorField& USource = eqn.source();
for(auto cell : cells)         {
USource[cell].x() = 1.0;
USource[cell].y() = 0.0;
USource[cell].z() = 0.0;
Info << USource << endl;
 Info << eqn.source() << endl;
The above two outputs are different and I am unable to understand why.
PART 2:
I also have a query below. Let's say I have modified my equation as below in mySolver.C by adding mySource, which I have also added in createFields.H
fvVectorMatrix UEqn
    fvm::ddt(U) + fvm::div(phi, U)
  + MRF.DDt(U)
  + turbulence->divDevReff(U)
  + mySource
    fvOptions(U)
Then is it possible to modify the value of mySource using fvOptions?
I tried the following but it didn't work.
codedSource
    type            vectorCodedSource;
    selectionMode   cellSet;
    cellSet         box1;
    fields          (mySource);
    name            sourceTime;
    codeConstrain //constrain
        return;
    codeCorrect //correct
            fld[cell].x() = 1.0;
I thought that "fields (mySource)" would give me access to the field for modification, but I don't think that happens. In fact nothing happens and no values are written to mySource, instead I get a warning
" Source codedSource defined for field mySource but never use".
Thank you!
Divyaprakash is offline   Reply With Quote
add source, fvoption, source
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Odd problem linking variables with field functions JRosser_Purdue STAR-CCM+ 1 December 12, 2022 13:31
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
potential flows, helmholtz decomposition and other stuffs pigna Main CFD Forum 1 October 26, 2017 09:34
Creating new variables and modify existing eqn in porousSimpleFoam AJAY BHANDARI OpenFOAM Programming & Development 3 December 2, 2015 03:17
