zzt
Rep Power: 5 ![]() |
I am writting my own solver. I encountered a problem when using adaptive mesh refinement. The error message indicated that it might be related to this line of code: volVectorField DUDt(fvc::DDt(phi_, Us_)); And I want to obtain the material derivative, is that right? Can someone kindly help me? Thank you. |
Ardalan
Rep Power: 14 ![]() |
Try your solver in a simplest condition as possible. I mean no adaptive mesh in this case. If it works fine, then the problem is not from your solver. The adaptive mesh is tricky to use. Try it from coarse resolution and with only a few layers and steps of refinements.
Display Modes | |
Breakup of VOF droplets due to adaptive mesh refinement | dplthuy | OpenFOAM Running, Solving & CFD | 5 | July 12, 2024 08:49 |
Data mapping with Adaptive Mesh Refinement | kapten_zoom | STAR-CCM+ | 0 | June 7, 2021 10:28 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 18:12 |
