Rep Power: 2 ![]() |
I am working with the twoPhaseEulerFoam solver and also using kineticTheoryModels. I want to observe the thermal conductivity "kappa" which is already defined as IOobject but in the file kineticTheoryModel.C as : kappa_ ( IOobject ( IOobject::groupName("kappa", phase.name()), U.time().timeName(), U.mesh(), IOobject::NO_READ, IOobject::NO_WRITE ), U.mesh(), dimensionedScalar("zero", dimensionSet(1, -1, -1, 0, 0), 0.0) ) Now I want to view this being written to case files, just like the other volScalarFields, so I changed the NO_WRITE to AUTO_WRITE and compiled my code. But it doesn't seem to do anything. Furthermore, if I try to print something by adding a "Info<<.." statement, I don't observe it in my log fiile. Is there a problem with my compilation? (I do wmake) or what is the other way I can observe kappa? Any help would be appreciated! Thanks in advance ![]() |
Hosein
Rep Power: 15 ![]() |
Hi there,
try adding Code:
writeKappa { type writeObjects; libs (utilityFunctionObjects); objects (kappa.particles); writeControl timeStep; writeInterval 1; } |
Dear einstein_zee,
Thankyou so much!! However I can't get the fields that I want at the correct time intervals. But that I can play around with ![]() Thanks a lot ![]() |
Display Modes | |
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" | GuiMagyar | OpenFOAM Meshing & Mesh Conversion | 3 | August 4, 2023 13:38 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
Error message | Bruno_Jorge | Main CFD Forum | 1 | February 5, 2019 12:12 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 12:27 |
