data transfer of lagrangian particle tracking in parallel |
Bill
Rep Power: 9 ![]() |
Hello everyone,
I am confronted with an issue of data transfer of lagrangian particle tracking in parallel. My details are as follows: 1) I rewrite the 'reactingParcel' code by adding some user-defined parameters for my particle. 2) I complied the revised 'reactingParcel' and no errors. 3) i used the new solver and run it in serial. I can obtain the results i want. 4) However, when I run the solver in parallel. My results are wrong. 5) I debugged the code and finnally found that the issue is caused by the data transfer in parallel. In parallel, when particle moves to a new subdomain, we need to transfer the particle data. As for my calculation, particle tracking is relied on the new particle parameters I defined therefore I also need to properly trasfer these data. So I think I didnt properly transfer these data. Could you help with this issue? The following information explains how I define, read and save the new particle parameters in the "reactingParcel" source code. 6) create the member parameters and member functions of the particle parameters I need in the "reactingParcel.H", just like the in-built parameter 'mass0_' and its related member function. 7) define the member function in "reactingParcelI.H" 8) Initialize the member parameter in the constractors in "reactingParcel.C" and ""reactingParcelIO.C"". After carefully reading the source code, I think this part codes are very important for parallel Code:
//- Factory class to read-construct particles used for // parallel transfer class iNew { const polyMesh& mesh_; public: iNew(const polyMesh& mesh) : mesh_(mesh) {} autoPtr<ReactingParcel<ParcelType>> operator()(Istream& is) const { return autoPtr<ReactingParcel<ParcelType>> ( new ReactingParcel<ParcelType>(mesh_, is, true) ); } }; Code:
template<class ParcelType> Foam::ReactingParcel<ParcelType>::ReactingParcel ( const polyMesh& mesh, Istream& is, bool readFields ) : ParcelType(mesh, is, readFields), mass0_(0.0), Y_(0) { if (readFields) { DynamicList<scalar> Ymix; if (is.format() == IOstream::ASCII) { is >> mass0_ >> Ymix; } else { is.read(reinterpret_cast<char*>(&mass0_), sizeofFields_); is >> Ymix; } Y_.transfer(Ymix); } // Check state of Istream is.check ( "ReactingParcel<ParcelType>::ReactingParcel" "(" "const polyMesh&, " "Istream&, " "bool" ")" ); } Code:
template<class ParcelType> Foam::ReactingParcel<ParcelType>::ReactingParcel ( const polyMesh& mesh, Istream& is, bool readFields ) : ParcelType(mesh, is, readFields), mass0_(0.0), Y_(0), Rep_(0), // my new parameter MR_(0.0), // my new parameter E_AspectRatio_(1.0), // my new parameter sphericity_(1.0), // my new parameter phaseChangeStage_(0), // my new parameter Tcell_(0.0), // my new parameter integrationSteps_(0) // my new parameter { if (readFields) { DynamicList<scalar> Ymix; if (is.format() == IOstream::ASCII) { is >> mass0_ >> Ymix; Rep_ = readScalar(is); // my new parameter MR_ = readScalar(is); // my new parameter E_AspectRatio_ = readScalar(is); // my new parameter sphericity_ = readScalar(is); // my new parameter phaseChangeStage_ = readLabel(is); // my new parameter Tcell_ = readScalar(is); // my new parameter integrationSteps_ = readLabel(is); // my new parameter } else { is.read(reinterpret_cast<char*>(&mass0_), sizeofFields_); is >> Ymix; } Y_.transfer(Ymix); } // Check state of Istream is.check ( "ReactingParcel<ParcelType>::ReactingParcel" "(" "const polyMesh&, " "Istream&, " "bool" ")" ); } |
Bill
I managed to resolve this issue. We need to stickly follow how openfoam save and write class member parameters.
Display Modes | |
Eulerian Multiphase Model vs Lagrangian Particle Tracking | ajjadhav | CFX | 14 | December 7, 2020 17:22 |
Lagrangian particle tracking in mechanically agitated mono-dispersed and poly-dispers | anandjjadhaviitr | ANSYS | 0 | September 18, 2020 16:19 |
[OpenFOAM] How to get the coordinates of velocity data at all cells and at all times | vidyadhar | ParaView | 9 | May 20, 2020 21:06 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 11:52 |
Check particle impaction with User Fortran | Julian K. | CFX | 3 | January 12, 2012 10:46 |
