[ERROR] IF logic
Old   January 20, 2025, 18:23
Default [ERROR] IF logic
gu1
Guilherme
gu1 is on a distinguished road
I'm having trouble implementing if logic in my code (OpenFOAM 9). I need help.
const volScalarField Lt(this->Lt());
const volScalarField delta(this->delta());
const scalar tmp = 0;
if (Lt == delta)
      tmp = Ck_*sqrt(k_)*Lt;
this->nut_ = tmp
this->nut_.correctBoundaryConditions();
fvConstraints::New(this->mesh_).constrain(this->nut_);
ERROR:
error: no match for ‘operator==’ (operand types are ‘const volScalarField’ {aka ‘const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>’} and ‘const volScalarField’ {aka ‘const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>’})
  229 |     if (Lt == delta)
      |         |     GeometricField<[...],[...],[...]>
error: assignment of read-only variable ‘tmp’
  231 |         tmp = Ck_*sqrt(k_)*Lt;
Thanks
gu1 is offline   Reply With Quote
Old   January 25, 2025, 17:35
Default internal field referencing?
Jim Park
bmb333 is on a distinguished road
Have you tried .internalField()?
For example,
if (Lt.internalField() == delta.internalField()) ...
bmb333 is offline   Reply With Quote
openfoam9
[mesh manipulation] [Error] Wedge patch 'frontAndBackPlanes' is not planar Danny_cfd OpenFOAM Meshing & Mesh Conversion 0 June 4, 2021 10:32
[Error] SIGSERV when continuing simulation Luiz FLUENT 0 March 28, 2019 18:52
[Error] Fluent Not Responding on Workbench Environment Luiz FLUENT 8 September 5, 2018 22:55
can anyone explian the logic behind defining the vertices gandesk OpenFOAM 3 November 11, 2010 01:18
Streamline plotting logic soggy316 Main CFD Forum 8 July 10, 2009 09:14
