PIMPLE iterations in the implementation of boundary condition
Old   January 28, 2025, 04:31
Default PIMPLE iterations in the implementation of boundary condition
Filippo
Filippo70 is on a distinguished road
Hi foamers.
I'm working on the implementation of a pressure boundary condition in OpenFoam2012 and would like to update it at the conclusion of the inner pimple cycle (finalInnerIteration). Is it feasible to perform this within a boundary condition?
I noticed that, from the pimple.C file, the object 'pimple' comes from 'createPimpleControl.H' and depends on 'mesh':
 pimpleControl pimple(mesh)
but if i obtain mesh information and create the 'pimple' object with:
fvMesh& mesh = this->patch().boundaryMesh().mesh();
pimpleControl pimple(mesh);
I receive this error:
In instantiation of ‘void Foam:: pressureInletOutletWkFvPatchField<Type>::updateCoe ffs() [with Type = Foam::Tensor<double>]’:
pressureInletOutletWkFvPatchField.C:163:6: required from here
pressureInletOutletWkFvPatchField.C:172:18: error: binding reference of type ‘Foam::fvMesh&’ to ‘const Foam::fvMesh’ discards qualifiers
172 | pimpleControl pimple(mesh);
I believe this is related to the fact that the pimpleControl constructor expects a non-const object.
Thank you in advance for your response.
Filippo70 is offline   Reply With Quote
Old   February 6, 2025, 10:50
Filippo
After many attempts I solved the problem with the following lines of code:
const pimpleControl& pc = db().lookupObject<pimpleControl>
      "solutionControl"
After that, i'm able to call all the functions contain in "pimpleControl.H".
Perhaps these last lines of code may also be useful to others.
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 13:47
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
