Modification of reactingFoam solver to FGMFoam solver
Old   February 6, 2025, 14:07
Default Modification of reactingFoam solver to FGMFoam solver
Killua Zoldyck
killua1915 is on a distinguished road
I am trying to follow tutorial by Michael Bertsch to compile FGMFoam from reactingFoam.
https://www.tfd.chalmers.se/~hani/ku...rt_FGMFoam.pdf
I am getting following error and I am not sure what is the issue here.
build_log.zip
Any idea on how to resolve this ?
HTML Code:
In file included from FGMFoam.C:88:PVEqn.H: In function ‘int main(int, char**)’:PVEqn.H:8:20: error: ‘class Foam::CombustionModel<Foam::psiReactionThermo>’ has no member named ‘SourcePV’    8 |          reaction->SourcePV()   //--- added by senbin, 2019-04-26      |                    ^~~~~~~~
HTML Code:
make: *** [/usr/lib/openfoam/openfoam2406/wmake/rules/General/transform:38: Make/linux64GccDPInt32Opt/FGMFoamPost.o] Error 1
The source code of file is given below.
https://drive.google.com/file/d/1ZL3...ew?usp=sharing
killua1915 is offline   Reply With Quote
Old   February 7, 2025, 05:02
Domenico Lahaye
dlahaye is on a distinguished road
I suggest to use the version of OpenFoam for which the code was developed.
See also post related to FGM on this forum.
dlahaye is offline   Reply With Quote
Old   February 7, 2025, 09:15
Killua Zoldyck
I am not sure in which version it was written. Most files have following comment at top.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration |
\\ / A nd | www.openfoam.com
\\/ M anipulation |
Copyright (C) 2011-2015 OpenFOAM Foundation
Old   February 7, 2025, 11:52
Domenico Lahaye
Not sure either. I believe something like OpenFoam-2.2 or 2.3.
The alternative approach is to persue a new implementation. A function object to compute the mixture fraction is already available. Next step its to extend to. computation of the mixture fraction variance.
Old   February 10, 2025, 04:11
Killua Zoldyck
I have successfully compiled and run the FGMFoam for SandiaD flame tutorial. But I am getting following warnings.
Duplicate entry cubeRootVol in runtime table LESdelta
[stack trace]
I have went through some threads in this forums but I am not sure which library linkage is causing this issue. Any idea on this ?
Old   February 10, 2025, 06:43
Domenico Lahaye
Not sure.
Is the entry "cubeRootVol" by mistake repeated in some input file?
Old   February 10, 2025, 07:04
Killua Zoldyck
Not really. I have tried using grep function to find and I am getting following results :
./TurbulenceModels/turbulenceModels/RAS/kOmegaSSTSAS/kOmegaSSTSAS.H: delta cubeRootVol;
./TurbulenceModels/turbulenceModels/RAS/kOmegaSSTSAS/kOmegaSSTSAS.H: cubeRootVolCoeffs
./TurbulenceModels/turbulenceModels/LES/LESdeltas/vanDriestDelta/vanDriestDelta.H: delta cubeRootVol;
./TurbulenceModels/turbulenceModels/LES/LESdeltas/vanDriestDelta/vanDriestDelta.H: cubeRootVolCoeffs
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.H: Foam::cubeRootVolDelta
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.H: cubeRootVolDelta.C
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.H:#ifndef cubeRootVolDelta_H
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.H:#define cubeRootVolDelta_H
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.H: Class cubeRootVolDelta Declaration
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.H:class cubeRootVolDelta
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.H: cubeRootVolDelta(const cubeRootVolDelta&) = delete;
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.H: void operator=(const cubeRootVolDelta&) = delete;
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.H: TypeName("cubeRootVol");
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.H: virtual ~cubeRootVolDelta() = default;
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C:#include "cubeRootVolDelta.H"
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C: defineTypeNameAndDebug(cubeRootVolDelta, 0);
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C: addToRunTimeSelectionTable(LESdelta, cubeRootVolDelta, dictionary);
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C:void Foam::LESModels::cubeRootVolDelta::calcDelta()
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C:Foam::LESModels::cubeRootVolDel ta::cubeRootVolDelta
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C:void Foam::LESModels::cubeRootVolDelta::read(const dictionary& dict)
./TurbulenceModels/turbulenceModels/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C:void Foam::LESModels::cubeRootVolDelta::correct()
./TurbulenceModels/turbulenceModels/LES/LESdeltas/maxDeltaxyzCubeRootLESDelta/maxDeltaxyzCubeRootLESDelta.C: cubeRootVolDelta_.calcDelta();
./TurbulenceModels/turbulenceModels/LES/LESdeltas/maxDeltaxyzCubeRootLESDelta/maxDeltaxyzCubeRootLESDelta.C: static_cast<const volScalarField&>(cubeRootVolDelta_)
./TurbulenceModels/turbulenceModels/LES/LESdeltas/maxDeltaxyzCubeRootLESDelta/maxDeltaxyzCubeRootLESDelta.C: name + "cubeRootVolDelta",
./TurbulenceModels/turbulenceModels/LES/LESdeltas/maxDeltaxyzCubeRootLESDelta/maxDeltaxyzCubeRootLESDelta.C: cubeRootVolDelta_.read(dict.subDict(typeName + "Coeffs"));
./TurbulenceModels/turbulenceModels/LES/LESdeltas/maxDeltaxyzCubeRootLESDelta/maxDeltaxyzCubeRootLESDelta.H: Maximum delta between maxDeltaxyz and cubeRootVolDelta.
./TurbulenceModels/turbulenceModels/LES/LESdeltas/maxDeltaxyzCubeRootLESDelta/maxDeltaxyzCubeRootLESDelta.H:#include "cubeRootVolDelta.H"
./TurbulenceModels/turbulenceModels/LES/LESdeltas/maxDeltaxyzCubeRootLESDelta/maxDeltaxyzCubeRootLESDelta.H: //- cubeRootVolDelta model
./TurbulenceModels/turbulenceModels/LES/LESdeltas/maxDeltaxyzCubeRootLESDelta/maxDeltaxyzCubeRootLESDelta.H: cubeRootVolDelta cubeRootVolDelta_;
./TurbulenceModels/turbulenceModels/LES/LESdeltas/PrandtlDelta/PrandtlDelta.H: delta cubeRootVol;
./TurbulenceModels/turbulenceModels/LES/LESdeltas/PrandtlDelta/PrandtlDelta.H: cubeRootVolCoeffs
./TurbulenceModels/turbulenceModels/Make/linux64GccDPInt32Opt/sourceFiles:$(LESdelta)/cubeRootVolDelta/cubeRootVolDelta.C \
./TurbulenceModels/turbulenceModels/Make/linux64GccDPInt32Opt/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C.dep:$(OBJECTS_DIR)/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C.dep: \
./TurbulenceModels/turbulenceModels/Make/linux64GccDPInt32Opt/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C.dep:LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C \
./TurbulenceModels/turbulenceModels/Make/linux64GccDPInt32Opt/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.C.dep:LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.H \
grep: ./TurbulenceModels/turbulenceModels/Make/linux64GccDPInt32Opt/LES/LESdeltas/cubeRootVolDelta/cubeRootVolDelta.o: binary file matches
grep: ./TurbulenceModels/turbulenceModels/Make/linux64GccDPInt32Opt/LES/LESdeltas/maxDeltaxyzCubeRootLESDelta/maxDeltaxyzCubeRootLESDelta.o: binary file matches
./TurbulenceModels/turbulenceModels/Make/linux64GccDPInt32Opt/LES/LESdeltas/maxDeltaxyzCubeRootLESDelta/maxDeltaxyzCubeRootLESDelta.C.dep:lnInclude/cubeRootVolDelta.H \
./TurbulenceModels/turbulenceModels/Make/files:$(LESdelta)/cubeRootVolDelta/cubeRootVolDelta.C
Old   February 10, 2025, 07:34
Domenico Lahaye
1/ Suggest to check the case files (system/ and constant/) using grep;
2/ Suggest to share entire log file (allowing to check how and where the error message appears);
Old   February 10, 2025, 09:18
Killua Zoldyck
log.zip
Please find attached log files.
Old   February 10, 2025, 09:27
Domenico Lahaye
It is possible that errors are due to v2406 being used?
Old   February 10, 2025, 09:36
Killua Zoldyck
Not sure. I have tried compiling it in version v2206 as you recommended previously but I was getting same warnings. The solver is running fine but it gives these warnings which I am not sure why.
Old   February 10, 2025, 09:45
Domenico Lahaye
I was recommending going back way earlier and compile against even older versions of openfoam. Apologies for not being sufficiently clear.
What are the simulation results like?
Old   February 10, 2025, 10:22
Killua Zoldyck
Haven't had the chance to look at it properly but based on initial expectation, contour plots for temperature and OH radicals are quite close as given in this tutorial.
Old   February 12, 2025, 06:20
Killua Zoldyck
For anyone wondering how I got rid of these warnings, I renamed all the classes which were mentioned in the warning. Crude approach but it worked. I have tried copying library from src to my local and recompiling it with different name but not sure why it didn't work.
temp dependent density Linas Fluent UDF and Scheme Programming 2 February 13, 2025 19:22
Get the rate of reactions from the reactingFoam solver Mirza8 OpenFOAM Post-Processing 10 June 24, 2024 03:37
Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Kieyo Fluent Multiphase 0 November 10, 2022 00:58
Error SIGSEGV using VOF and UDF JERC_UTFSM Fluent UDF and Scheme Programming 14 November 8, 2021 00:17
Is it possible to accelerate the ode solver of reactingFoam? pajofego OpenFOAM Running, Solving & CFD 2 August 10, 2014 06:38
