dgdt in multiphase compressible Flows??!!!
Like Tree2Likes
  • 1 Post By mostanad
  • 1 Post By Tobermory
Old   February 6, 2025, 18:26
Default dgdt in multiphase compressible Flows??!!!
mohammad
mostanad is on a distinguished road
Dear OpenFOAM users,
I am working with the compressibleMultiphaseInterFOAM solver, which handles N compressible phases with thermophysical properties. I have successfully derived the equations for \alpha_i and pressure, according to this thread Formulation in compressibleInterFoam, but something has been bothering me—I believe there must be some physical reasoning behind it.
If we look at the derivation for \alpha_i, it should simply be as follows:
However, based on the concept of defining dgdt as compressibility:
https://github.com/OpenFOAM/OpenFOAM...am/pEqn.H#L106
We rewrite the \alpha_i​ equation by incorporating other phases compressibilities, as follows:
Mathematically, this expression is equivalent to the one in the first image.
But my question is: Why? The first expression seems more straightforward to me.
mostanad is offline   Reply With Quote
Old   February 9, 2025, 18:45
mohammad
No idea about this?
Old   March 5, 2025, 17:59
mohammad
Well, I think I’ve kind of found the answer to my question. Including the compressibility of other phases in one phase's void fraction equation is important because the phase needs to account for how the compressibility of other phases affects its volume fraction.
In other words, this form of the equation allows the phase to consider its own compressibility while also incorporating the effects of other phases' compressibility, specifically at the interface, which is crucial for maintaining a homogeneous and closed system of equations.
Tobermory likes this.
Old   March 7, 2025, 06:18
Tobermory will become famous soon enough
Sounds good to me! Thanks for taking the time to share.
mostanad likes this.
Tobermory is offline   Reply With Quote
problems at multiphase flows, emptying a bottle mvo CFX 6 February 29, 2016 09:28
Calculating mass flow rate at multiphase flows Kuslo187 OpenFOAM Post-Processing 1 August 21, 2015 18:11
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 05:29
Using Compressible Solver (sonicFoam) to solve subsonic flows ezsoal OpenFOAM 0 October 27, 2009 09:13
Case check - Velocity-Inlet not compatible with compressible flows fluent-user FLUENT 2 September 15, 2009 08:46
