How to define a custom value and read an update from the fvSolution file?
Old   March 4, 2025, 12:21
Default How to define a custom value and read an update from the fvSolution file?
Klaus
klausb will become famous soon enough
I am working in some customizations involving the PCG source code. I need to be able to set and update values from the fvSolution file, solvers, p section. The code below includes the relevant code sections. The code compiles fine.
The problem is, that the value from the fvSolution file is not read, the default values are not changeing, when I set a different value in the fvSolution file.
How to read a value from fvSolution file, solvers, p section for use within PCG.C?
#include "myPCG.H"
#include "PrecisionAdaptor.H"
#include "SquareMatrix.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
    defineTypeNameAndDebug(myPCG, 0);
    lduMatrix::solver::addsymMatrixConstructorToTable<myPCG>
        addmyPCGSymMatrixConstructorToTable_;
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::myPCG::myPCG
    const word& fieldName,
    const lduMatrix& matrix,
    const FieldField<Field, scalar>& interfaceBouCoeffs,
    const FieldField<Field, scalar>& interfaceIntCoeffs,
    const lduInterfaceFieldPtrsList& interfaces,
    const dictionary& solverControls
    lduMatrix::solver
        fieldName,
        matrix,
        interfaceBouCoeffs,
        interfaceIntCoeffs,
        interfaces,
        solverControls
    eigenvaluesComputed_(false),  // Correct initialization in the initializer list
    eigRatio_(solverControls.lookupOrDefault<scalar>("eigRatio", 1.5)) // This doesn't read the value from the fvSolution file
    // Optional: Print the values for debugging
    if ((log_ >= 2) || (lduMatrix::debug >= 2))
        Info<< "Eigenvalues Parameters:" << nl
            << "    eigRatio: " << eigRatio_ << nl
            << endl;
klausb is offline   Reply With Quote
Old   March 6, 2025, 08:06
Eren
ErenC is on a distinguished road
I'm not sure about the exact procedure but I can suggest you this:
Start from src/OpenFOAM/matrices/solution. You'll see the entries that solver excepts from you. You can define a new entry there and call it in your function maybe.
ErenC is offline   Reply With Quote
Old   March 7, 2025, 07:25
Tobermory will become famous soon enough
Here's another suggestion to try. It sounds as if it is not finding the eigRatio dictionary entry ... so maybe it's looking in the wrong place? Try changing the lookupOrDefault to lookup and force an error - it will then hopefully tell you where it's looking.
Tobermory is offline   Reply With Quote
