basic question regarding transform in rigidBodyMotionCoeffs
Old   March 14, 2025, 07:01
Default basic question regarding transform in rigidBodyMotionCoeffs
zog
Jacques
zog is on a distinguished road
I am struggling to find the .H / .C files where the "transform" is used.
FoamFile
    format      ascii;
    class       dictionary;
    object      dynamicMeshDict;
mover
    type            motionSolver;
    libs            ("librigidBodyMeshMotion.so");
    motionSolver       rigidBodyMotion;
        report          on;
        solver
            type Newmark;
        accelerationRelaxation 0.7;
        bodies
            floatingObject
                type            cuboid;
                parent          root;
                // Cuboid dimensions
                L               (0.1 0.1 0.1);
                // Density of the cuboid
                rho             800;
                // Cuboid mass
                mass            #calc "$rho*cmptProduct($<vector>L)";
                centreOfMass    (0 0.08 0.08);
                transform      (1 0 0 0 1 0 0 0 1) (0.4 0.45 0.35);
How should I proceed to find it (I tried banana but in this case it didn't help, and searching the API neither), for future reference ?
I got that it corresponds to the centre of rotation (geometrical centre of the floating object), and that it enables to place the centreofmass (given in local coordinates with 0 0 0 the centre of rotation) in the global coordinates system, but I really can't find the actual files where this is done in the C++ reference guide...
zog is offline   Reply With Quote
Old   March 21, 2025, 05:09
Amirhossein Taran
amirhosseintaran is on a distinguished road
FoamFile
    format      ascii;
    class       dictionary;
mover
    type            motionSolver;
        report          on;
        solver
            type Newmark;
        bodies
            floatingObject
                type            cuboid;
                parent          root;
                L               (0.1 0.1 0.1);
                rho             800;
                // Cuboid mass
I think the good starting point for this would be the rigidBody library itself.
Particularly in your case, within
PHP Code:
$FOAM_SRC
I can see there is a
PHP Code:
rigidBodyDynamics
So if I look for "transform" here, I would be able to get the definition/declaration of transform.
PHP Code:
grep -nr "transform"
then one of the outputs would be:
PHP Code:
./rigidBodyModel/rigidBodyModel.C:201:                bodyDict.get<spatialTransform>("transform"),
Hope this helps.
amirhosseintaran is offline   Reply With Quote
Basic question about iteration process aerosayan Main CFD Forum 7 December 20, 2020 21:53
Basic question about local timestepping aerosayan Main CFD Forum 3 December 20, 2020 08:19
[Other] very basic question about createPhi.H feldy77 OpenFOAM Meshing & Mesh Conversion 2 November 22, 2011 08:16
Basic question forsumit OpenFOAM 0 April 7, 2010 10:46
Basic Question Abhi FLUENT 1 August 4, 2007 08:07
