Is there a trigger that tells me whether the matrix has changed
Old   April 10, 2025, 20:13
Default Is there a trigger that tells me whether the matrix has changed
Klaus
klausb will become famous soon enough
I am looking for a (boolean) trigger that tells me whether the matrix has changed since the last check to be able to cache and re-use data.
The idea is to toggle between true and false and re-use data as often as possible to avoid expensive re-calculations.
Is there something like that?
klausb is offline   Reply With Quote
Old   April 23, 2025, 09:47
Amirhossein Taran
amirhosseintaran is on a distinguished road
Hi Klaus,
I don't understand why you can't define this boolean yourself.
e.g. comparing the matrix with itself shows whether it has changed or not!
Regards,
Amir.
amirhosseintaran is offline   Reply With Quote
Old   April 25, 2025, 14:00
Junchao Zhang
jczhang is on a distinguished road
Originally Posted by amirhosseintaran View Post
Hi Klaus,
Regards,
Amir.
Wow, I also had the same question. To compare, you need to save the old matrix. There is a cost in saving the matrix and then comparing. We want to avoid the cost.
jczhang is offline   Reply With Quote
Old   April 27, 2025, 05:13
Klaus
The point is indeed, that comparing entire matrices has a significant impact on data storage requirements and overall performance even when using hash algorithms and I am looking for ways to speed simulations up.
Old   April 28, 2025, 00:00
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Just save the sum of diagonals and sum of off diagonals in two variables. Just compare these two values and see if they changed above a thresold.
You can also add, min, max of dia and min max of off diagonals. This was you do not need to store last matrix.
arjun is offline   Reply With Quote
Old   April 28, 2025, 09:57
Junchao Zhang
I feel all these approach are unsafe with respect to false positive, i.e., the sums of entries of two matrices are equal but the two matrices are not equal.
Old   April 29, 2025, 07:45
Arjun
Only way to be hundred percent sure is to cache the matrix. Any other method will always have some doubts.
Old   April 29, 2025, 23:47
Junchao Zhang
It depends on the design. For example, in petsc a matrix has a two integer attributes: state and nonzerostate. Whenever the sparsity pattern changed, the nonzerostate is increased; and whenever an operation modifying matrix values is called, the state is increased. With that, one can easily and safely detect matrix changes.
Old   May 1, 2025, 04:05
Domenico Lahaye
dlahaye is on a distinguished road
1/ I think it is save to assume that the matrix changes at every inner iteration of e.g. a SIMPLE iteration. You might this be looking for deviations from this rule;
2/ When is matrix assembly a computational bottleneck?
dlahaye is offline   Reply With Quote
Old   May 2, 2025, 07:08
Klaus
@dlahaye
>> Not really, it depends on the simulation type, e.g. moving mesh...
>> It's not. A matrix change, changes the eigenvalues, which triggers computationally expensive re-calculations which I want to keep to a minimum
Old   May 2, 2025, 08:39
Arjun
Then i think you do not understand the problem that has been discussed.
Every iteration an operation modiying the matrix IS performed thanks to descretization.
What we are talking about is matrix being same as last iteration that one obtained after descretization. This matrix will stop to be different once the convergence is achieved.
Access and modify zero matrix coefficient thang_cegroup OpenFOAM Programming & Development 0 April 16, 2019 23:01
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) Adam_K OpenFOAM Running, Solving & CFD 2 March 27, 2019 06:51
How can I get the number of elements per row form the matrix? klausb OpenFOAM Programming & Development 2 December 30, 2018 15:27
Changing viewfactor Model and use the changed my model by calling "mySolver" FabianF OpenFOAM Programming & Development 2 January 14, 2014 11:25
How to find the product of A+ matrix and A- matrix arjun shanker Main CFD Forum 0 November 12, 2010 22:12
