openFoamv13 Third-Party compilation error: *** missing separator. Stop.
Old   October 7, 2025, 07:12
Default openFoamv13 Third-Party compilation error: *** missing separator. Stop.
AlxB is on a distinguished road
Dear Foamers,
I can compile a third party library in OpenFOAMv2412 ESI version but can't do the same in OpenFOAMv13. However the installation is different as OFv2412 is on a machine with Ubuntu 20.04 and OFv13 is on a machine with Ubuntu 22.04.
So when I try to compile it then I get this message:
ThirdParty/PhreeqcRM$ ./Allwmake
+ wmake libso src
wmake libso src
Make/linux64GccDPInt32Opt/files:1: *** missing separator.  Stop.
here is the 'files' content:
IPhreeqcPhast/IPhreeqc/phreeqcpp/common/Parser.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/common/PHRQ_base.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/common/PHRQ_io.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/common/Utils.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/PhreeqcKeywords/Keywords.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/advection.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/basicsubs.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/ChartHandler.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/ChartObject.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/cl1.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/CurveObject.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/cvdense.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/cvode.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/cxxKinetics.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/cxxMix.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/dense.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/Dictionary.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/dumper.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/Exchange.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/ExchComp.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/GasComp.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/gases.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/GasPhase.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/input.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/integrate.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/inverse.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/ISolution.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/ISolutionComp.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/isotopes.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/kinetics.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/KineticsComp.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/mainsubs.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/model.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/NameDouble.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/NumKeyword.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/nvector.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/nvector_serial.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/parse.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/PBasic.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/phqalloc.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/Phreeqc.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/PHRQ_io_output.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/pitzer.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/pitzer_structures.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/PPassemblage.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/PPassemblageComp.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/prep.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/Pressure.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/print.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/Reaction.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/read.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/ReadClass.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/readtr.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/runner.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/SelectedOutput.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/Serializer.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/sit.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/smalldense.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/Solution.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/SolutionIsotope.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/spread.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/SS.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/SSassemblage.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/SScomp.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/step.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/StorageBin.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/StorageBinList.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/structures.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/sundialsmath.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/Surface.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/SurfaceCharge.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/SurfaceComp.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/System.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/tally.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/Temperature.cxx
IPhreeqcPhast/IPhreeqc/phreeqcpp/tidy.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/transport.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/Use.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/UserPunch.cpp
IPhreeqcPhast/IPhreeqc/phreeqcpp/utilities.cpp
IPhreeqcPhast/IPhreeqc/CSelectedOutput.cpp
IPhreeqcPhast/IPhreeqc/IPhreeqc.cpp
IPhreeqcPhast/IPhreeqc/IPhreeqc_interface_F.cpp
IPhreeqcPhast/IPhreeqc/IPhreeqcLib.cpp
IPhreeqcPhast/IPhreeqc/Var.c
IPhreeqcPhast/IPhreeqcPhast.cxx
IPhreeqcPhast/IPhreeqcPhastLib.cpp
PhreeqcRM.cpp
RM_interface_C.cpp
RM_interface_F.cpp
LIB = $(WM_PROJECT_USER_DIR)/ThirdParty/PhreeqcRM/lib/libPhreeqcRM
I checked the entire src/Make/files is plain ASCII with no CR, BOM, or stray indentation, with spaces and no tabs.
Would it be someone who have experienced this ? And what the fix could be ?
Many thanks in advance for you help
AlxB is offline   Reply With Quote
Old   October 23, 2025, 02:28
Dear foamers,
if i do the compilation on OF v2412 then it works well:
~/OpenFOAM/user-2412/ThirdParty/PhreeqcRM$ ./Allwmake
+ wmake libso src
wmake libso src
    ln: ./lnInclude
Making dependencies: RM_interface_F.cpp
g++ -std=c++17 -m64 -pthread -DOPENFOAM=2412 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100  -fopenmp -DUSE_OPENMP -w -iquote. -IlnInclude -I/usr/lib/openfoam/openfoam2412/src/OpenFOAM/lnInclude -I/usr/lib/openfoam/openfoam2412/src/OSspecific/POSIX/lnInclude   -fPIC -c IPhreeqcPhast/IPhreeqc/phreeqcpp/GasPhase.cxx -o Make/linux64GccDPInt32Opt/IPhreeqcPhast/IPhreeqc/phreeqcpp/GasPhase.o
The compiler on OF13 is Gcc as well.
So what could explain it does not start with the same library file ?
~/OpenFOAM/user-13/ThirdParty/PhreeqcRM$ ./Allwmake
+ wmake libso src
wmake libso src
Thank you
compilation error, missing separator, openfoamv13, phreeqcrm library
Compilation error for OpenFoam FSI solver with third party FEA code danny261083 OpenFOAM Running, Solving & CFD 1 October 6, 2017 10:50
[waves2Foam] Problems with the compilation of the third party dependencies chia87 OpenFOAM Community Contributions 7 May 20, 2017 07:04
Compilation Error (V 1.7.1; Icc 12.1.0, OpenMPI 1.4.3) floydfan OpenFOAM Installation 7 December 20, 2011 06:56
