[Sponsors] | |||||
Rep Power: 0 ![]() |
Dear OpenFoam Users,
please forgive if I've done something wrong - this is my first time on Forum so I did not know if I should I continue an old thread from 2016 or start a new one - I decided for the 2nd option. I'm trying to set up a simulation domain consisting of several sub-domains (geometry and mesh done in Salome and imported to OpenFoam). Two sub-domains I have to connect and decided to do that by cyclicAMI - though those sub-domains will be stationary - just have to connect / interpolate the meshes as the flow will pass those 2 sub-domains. After typing moveDynamicMesh - checkAMI I get the following information as shown below. I have tried to increase the matchTolerance value in createPatchDict (maybe it was set to small and the 2 meshes could not see each other) - but without any results. I've checked the normals at those 2 domains - in both cases show outside of the 2 sub-domains so it seems to be consistent. The mesh sizes at those 2 sub-domains also do not differ much. I've no idea why the target has such enormous dimensions and I do not know what to do to solve that problem so any suggestions / help are most welcome. Thank you in advance. PIMPLE: iteration 1 inverseDistance : detected 6 mesh regions zone:0 nCells:17535 voxels(57 57 57) bb(-57.4952657 -60.0001657 -10.5464657) (57.4991657 57.4123657 10.5708657) zone:1 nCells:60750 voxels(57 57 57) bb(-47.00013458 -47.00013458 -10.50013458) (47.00013458 47.00013458 10.50013458) zone:2 nCells:45884 voxels(57 57 57) bb(-49.00413874 -49.00473874 -10.50643874) (49.00413874 49.00563874 -4.493391264) zone:3 nCells:7455 voxels(57 57 57) bb(-57.50005815 -110.0000582 -10.50005815) (-36.49994185 -59.99994185 10.49985815) zone:4 nCells:29143 voxels(57 57 57) bb(-58.99012816 -87.45702816 -12.01112816) (-35.00977184 -81.63027184 1.551688159) zone:5 nCells:30613 voxels(57 57 57) bb-58.99012816 -87.45672816 -1.551528159) (-35.00987184 -81.63027184 12.01102816) AMI: Creating AMI for source:NewTorusKonektory_TorusWlotAMI and target:NewRdzenWlotAMI AMI: Patch source faces: 164 AMI: Patch target faces: 0 --> FOAM Warning : From void Foam::advancingFrontAMI::checkPatches() const in file AMIInterpolation/AMIInterpolation/advancingFrontAMI/advancingFrontAMI.C at line 107 Source and target patch bounding boxes are not similar source box span : (20.9904 0 20.8876) target box span : (-2e+150 -2e+150 -2e+150) source box : (-57.4951 -60 -10.4447) (-36.5047 -60 10.4429) target box : (1e+150 1e+150 1e+150) (-1e+150 -1e+150 -1e+150) inflated target box : (8.267949192e+149 8.267949192e+149 8.267949192e+149) (-8.267949192e+149 -8.267949192e+149 -8.267949192e+149) --> FOAM Warning : From bool Foam::advancingFrontAMI::initialiseWalk(Foam::labe l&, Foam::label&) in file AMIInterpolation/AMIInterpolation/advancingFrontAMI/advancingFrontAMI.C at line 219 164 source faces but no target faces AMI: Patch source sum(weights) min:0 max:0 average:0 AMI: Creating AMI for source:NewTorusKonektory_TorusWlotAMI and target:NewRdzenWlotAMI AMI: Patch source sum(weights) min:0.3565727449 max:2.021747123 average:0.5260444559 AMI: Patch target sum(weights) min:0.2954551436 max:0.6636438437 average:0.4610120731 --> FOAM FATAL ERROR: (openfoam-2406) Supplied field size is not equal to target patch size source patch = 164 target patch = 155 supplied field = 0 From void Foam::AMIInterpolation::interpolateToSource(const Foam::UList<T>&, const CombineOp&, Foam::List<T>&, const Foam::UList<T>&) const [with Type = Foam::meshToMeshData; CombineOp = Foam::combine<Foam::meshToMeshData, Foam::meshToMeshData::trackData>] in file /home/maciej/SoftwareInstalled/OpenFOAM/OpenFOAM-v2406/OpenFOAM-v2406/src/mes |
| Tags |
| cyclic ami, mesh 3d |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Using MRFSimpleFoam + CyclicAMI to simulate propeller/fan | Jason1114 | OpenFOAM Running, Solving & CFD | 0 | August 31, 2022 00:15 |
| cyclicAMI bc - Error: Unable to set source and target faces | Claire88 | OpenFOAM Pre-Processing | 0 | August 28, 2021 20:46 |
| OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 06:40 |
| OpenFOAM cases with cyclicAMI in tecPlot 360 | Aidan | Tecplot | 0 | January 24, 2016 11:57 |
| CyclicAMI Issue In OpenFOAM 2.2.0 | prasant | OpenFOAM Running, Solving & CFD | 17 | March 16, 2013 03:00 |
