Initalization of List<dimensionedScalar> with a proper dimensionSet
Old   November 5, 2025, 10:35
Default Initalization of List<dimensionedScalar> with a proper dimensionSet
Maciej Marczak
MMarczak is on a distinguished road
Hi everyone,
I am developing a custom solver in which I need to load some values from the dictionary at the beginning of the simulation.
I have a variable:
List<dimensionedScalar> solidSpeciesMolarMass_;
that initially was initialized by:
solidSpeciesMolarMass_(lookup("solidSpeciesMolarMass")),
But I kept getting runtime error:
--> FOAM FATAL ERROR:
Different dimensions for =
     dimensions : [0 0 0 0 0 0 0] = [1 0 0 0 -1 0 0]
I tried to find some workaround solution, like writing a helper function:
    List<scalar> vals(lookup("solidSpeciesMolarMass"));
    List<dimensionedScalar> mass;
    forAll(vals, i)
        mass.append
            dimensionedScalar
                Foam::name(i) + "_molarMass",
                dimensionSet(1, 0, 0, 0, -1, 0, 0),
                vals[i] * 1e-3
    return mass;
but it resulted with the same runtime error. I took a look at the constructors of the List class, but no solution came into my mind.
Is there any way that I can build a list of dimensionedScalar in this automatic way?
Thanks!
MMarczak is offline   Reply With Quote
What is the best proper value of second per iteration? dlalstnf SU2 1 April 6, 2023 13:54
[mesh manipulation] The extracted patch Labels in not proper for different test case. sunagra27 OpenFOAM Meshing & Mesh Conversion 0 May 31, 2021 04:08
how to get proper points location of geometry in CFD Post? teguhtf ANSYS 0 May 4, 2020 16:59
Proper cores number to be used in CFX simulation Anna Tian CFX 8 March 10, 2015 05:07
Constructing vector from three scalars mayank.dce2k7 OpenFOAM Running, Solving & CFD 8 January 28, 2014 17:07
