Invitation to Collaborate on Improving snappyHexMesh
Old   November 8, 2025, 11:27
Default Invitation to Collaborate on Improving snappyHexMesh
Temiz_CFD is on a distinguished road
Open-source CFD has reached a level where solvers like OpenFOAM can match commercial codes in accuracy and physical modeling.
What still holds us back is robust, fast, and reliable meshing.
The main open-source option today, snappyHexMesh, works but remains limited in several key aspects:
Current Weak Points
1. Performance
Meshing is significantly slower than commercial tools, especially for large or complex geometries.
The refinement and snapping stages consume disproportionate CPU time.
2. Boundary Layer Generation
Layer addition is unreliable—layers frequently collapse near sharp corners, tight gaps, or concave regions.
Achieving y+ ≈ 1 for wall-resolved turbulence models is difficult.
3. Parameter Overload
The number of parameters in snappyHexMeshDict is excessive.
Small changes in settings can drastically alter outcomes, forcing long trial-and-error cycles.
There is no clear connection between input parameters and resulting mesh quality metrics.
Call for Collaboration
If you are interested in:
Improving meshing speed and scalability,
Making layer generation more robust,
Simplifying parameter handling and automation,
then you are invited to join a community effort to improve snappyHexMesh (or develop a next-generation open-source mesher).
Input from all users is welcome—please share any experience, frustration, or feature you believe needs to be fixed or improved. Every insight helps identify priorities and shape development directions.
Let’s bring open-source meshing closer to the reliability of commercial tools—transparent, efficient, and community-driven.
S. B. Temiz
CFD Engineer | Temiz CFD – Cologne, Germany
Developer of Prefoam
🔗 www.temiz-cfd.de
 | 🎥 YouTube: youtube.com/@temizcfd
Temiz_CFD is offline   Reply With Quote
Old   November 19, 2025, 10:57
Klaus
klausb will become famous soon enough
I have been looking into open source meshing, too.
I am not sure, snappyHexMesh is a good starting point and would like to suggest to evaluate a possible rewrite of "Engrid" which suffers from an outdated code base but has all the capabilities you/we are looking for especially when it comes to boundary layer meshing.
There is no quick fix via debugging!
klausb is offline   Reply With Quote
Old   November 24, 2025, 05:13
Domenico Lahaye
dlahaye is on a distinguished road
Dear Klaus,
Many thanks for sharing your advice on this matter. Much appreciated.
Could you pls. elaborate on your suggestion? What should be done to bring Engrid to a modern implementation? Where should one start? What do you expect the gains to be?
Thanks again, Domenico.
dlahaye is offline   Reply With Quote
Old   November 25, 2025, 11:09
Franco
otaolafr is on a distinguished road
hello,
I would recommend instead of trying to improve snappyHexMesh, to try instead to bring other meshers to the toolkit. such as for example:
https://github.com/fprotais/marchinghex
this is one of the most interesting developments in opensource (but there are other octree meshers that could be interesting), for the moment it is missing some escential features such as refinement levels, nevertheless I think in my humble opinion, but snappy is just too complex, too many variables not reliable enough. a lot of us have tried to 'give a meaning' in regards to the impact of the parameters without too much luck.
or revive cfmesh.... which gives comparable quality with only one parameter, would be better to invest time on it.
otaolafr is offline   Reply With Quote
Klaus
Originally Posted by dlahaye View Post
Dear Klaus,
To my knowledge Engrid was and is the only open source meshing software that provides very good boundary layer meshing functionality. It's also very easy to use. Unfortunately, it's not possible to install it on a recent Linux distribution as the dependencies and codebase are outdated. Upgrading the dependencies and codebase results in an unstable, constantly crashing installation. My understanding from related discussions I had is, that the underlying codebase has diverged a lot in areas like memory management which causes these issues. I've tried both Engrid 1.4 and Engrid 2.0 and so have others.
With "a modern implementation" I mean practically a re-implementation using a current software stack which may or may not be the same Qt + VTK... but that's a question for a software architect and should consider the programming skill level that can be expected from the people interested in further developing Engrid. I could be wrong as I lack the deep rooted application development / software know-how required for such a project. Other aspects to consider is the development workload and the team required to maintain an open source software project in the long term.
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? klausb OpenFOAM Meshing & Mesh Conversion 1 March 7, 2015 12:55
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
