Error trying to access a variable
Old   September 23, 2009, 11:43
Default Error trying to access a variable
Danilo
ziooscuro is on a distinguished road
Hello people,
I have a quite strange problem... i had a working (till last week at least) solver, than i decide to upgrade the version......it compiles properly, the problem is that when i run a case (a case who was also running with the previous implementation) i get a segmentation error:
1#0 Foam::error:rintStack(Foam::Ostream&) in "/nfs/home/bruno/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/nfs/home/bruno/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 main in "/nfs/home/bruno/OpenFOAM/bruno-1.5/applications/bin/linux64GccDPOpt/evoluzione"
#4 __libc_start_main in "/lib64/libc.so.6"
#5 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/nfs/home/bruno/OpenFOAM/bruno-1.5/applications/bin/linux64GccDPOpt/evoluzione"
I run a LES simulation, and the problem occurs when i try to access the filter width in the line:
const volScalarField delta= turbulence->delta() ;
of course in my createFields there is:
Info << "Creating turbulence model.\n" << nl;
autoPtr<compressible::LESModel> turbulence
compressible::LESModel::New
rho,
U,
phi,
thermo()
I have no idea what's wrong.... any suggestion??
Thanks a lot
Danilo
ziooscuro is offline   Reply With Quote
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Error : access : Unknown variable & Phase-domain MKP FLUENT 0 August 28, 2006 03:40
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Error: access: unbound variable cfd-novice FLUENT 0 April 3, 2003 04:53
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
