Integration(math) issue
Old   November 9, 2015, 15:50
Default Integration(math) issue
Sandra
sabago is on a distinguished road
Hello Foamers!
This code might look familiar but I have added a few lines that require an integration that isn't going so well. Anyhoo, here's the code
forAll(x3, celli)
for (count=0; count<iter; count++)
        x3 = (x1 + x2)/2;
       jc = i*(Foam::exp(8.1*x))-(Foam::exp(-2.7*x))
	f1 = (Foam::exp(8.1*x1))-(Foam::exp(-2.7*x1))-(jc/i);
	f3 = (Foam::exp(8.1*x3))-(Foam::exp(-2.7*x3))-(jc/i);
	 if(neg(f1[celli] *f3[celli]))
            x2 = x3;
        else if((mag(x1[celli] - x2[celli]) < 1e-7)||(f3[celli]==0)||(jc[celli].integrate(0,3.6e9)==2e4))
            root =x3;
	    break;
	else
	x1= x3;
Info<<"Root is"<<endl;
Info<<root<<endl;
jc is declared as a volScalarField in my createFields and here's the error that I get (I understand that I do not have a double ie I understand what the error means but I do not know how to proceed.
error: request for member ‘integrate’ in ‘jc.Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::<anonymous>.Foam:imensionedField <double, Foam::volMesh>::<anonymous>.Foam::Field<double>::< anonymous>.Foam::List<double>::<anonymous>.Foam::U List<T>:perator[]<double>(celli)’, which is of non-class type ‘double’
Many thanks in advance,
Sandra
sabago is offline   Reply With Quote
Old   November 10, 2015, 03:20
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
1.
f3[celli]==0
in general it is not a good idea to compare doubles with ==. There are two functions:
inline bool equal(const Scalar& s1, const Scalar& s2)
    return mag(s1 - s2) <= ScalarVSMALL;
inline bool notEqual(const Scalar s1, const Scalar s2)
    return mag(s1 - s2) > ScalarVSMALL;
2. if jc is volScalarField then jc[celli] is just scalar (i.e. simple number), so
\int_a^b Cdx = Cx|_a^b = C(b -a)
And again this
will be FALSE 99,9% of the time.
alexeym is offline   Reply With Quote
Old   November 10, 2015, 03:51
Sandra
And again this
Would that formula work even if C is not a linear function per say (and I don't know its form either)? There's no method in OpenFOAM to get the area under a curve during simulation for volScalarFields like there's for doubles ie the integrate that I tried to use?
Lastly, out of curiosity, why would
be false 99.9% of the time?
Old   November 10, 2015, 04:10
Alexey Matveichev
If, as you said, jc is volScalarField, then jc[celli] can not be "...not a linear function per say...". It is a number and on a given time step it is in general even constant. I guess, you need to explain what you are trying to achieve with jc[celli].integrate(...). Right now what you are trying to do is like this:
(3.1415).integrate(0, 3e9)
Why do you need to integrate constant? What is integration variable?
https://isocpp.org/wiki/faq/newbie#floating-point-arith
https://en.wikipedia.org/wiki/Floati...uracy_problems
https://duckduckgo.com/?q=floating+point+comparison
Old   November 10, 2015, 04:27
Sandra
sorry, my bad....
jc in paraview (at each time step) is a curve like a straight up witch hat and I want to iterate until the area under that curve equals a constant that I give it (in this case, 20,000).
So, I agree, jc[celli] wouldn't work here but I wasn't thinking of that, unfortunately, when I tried it after "jc.integrate" gave me an error along the lines of "member doesn't have function integrate"
Old   November 10, 2015, 04:37
Alexey Matveichev
Well, let us start from the beginning...
What is jc? In the first post you wrote, that it is volScalarField, i.e. something that varies in VOLUME, then you have written, that it is "...a curve like a straight up witch hat...", i.e. someting that varies just in ONE direction (surely there are 3D curves, yet they usually can be reduced to function of one variable).
After you define jc, I think, it is easier to invent a method for calculation your "integral".
Old   November 10, 2015, 04:41
Sandra
it is defined as a volScalarField and calculated from the equation in the initial post BUT my case is 2D ie I have front and back patches empty so technically it's an areaScalarField if that were a thing in OpenFOAM and that's why I talked about a 2d curve.
Does that help?
Sandra
Old   November 10, 2015, 04:58
Alexey Matveichev
OK, your case is 2D, so is jc a surface? So you have
jc = jc(x, y)
and would like to calculate
\int_{x_a}^{x_b} \int_{y_a}^{y_b} jc\left(x, y\right)dxdy
where xa, xb, ya, yb are the corners of your simulation domain (so it would be volume under the curve and in simplest form it is a sum of jc[celli]*mesh.V()[celli]/<distance in empty direction>)?
Or you would like to take values of jc along the line L (technically reducing surface to curve) and them integrate 1D function along L?
Old   November 10, 2015, 05:03
Sandra
jc = jc(x, y)
The second option, please
\int_{x_a}^{x_b}jc\left(x \right)dx
Many thanks, BTW
Old   November 10, 2015, 05:30
Alexey Matveichev
There are several possibilities:
1. Your mesh is static regular orthogonal, your line is parallel to axis. You construct cell set (cells, where you line passes) yourself in the beginning of the simulation, starting from xa (using, for example, findCell method of mesh) and then iterating through the neighbors and selecting cells in required direction (or if mesh is not large, you can use findCell for every point of your line, as you are doing it just once). After in simplest case you iterate through the labels, take value of jc in the cell, take width of the cell and multiply.
2. You mesh is static irregular, your line is defined as a*x + b. You can use polyLineSet set class to construct cell set.
3. You mesh moves, is irregular, your line is defined as a*x + b. You reconstruct cell set using polyLineSet after every mesh topological change.
[swak4Foam] swak4Foam 0.3.1 OF2.2.2 Installation Issue scnsc OpenFOAM Community Contributions 3 August 20, 2014 07:59
Strange issue while launching ANSYS workbench in CentOS 6.4 Philip_C ANSYS 11 August 29, 2013 06:44
CyclicAMI Issue In OpenFOAM 2.2.0 prasant OpenFOAM Running, Solving & CFD 17 March 16, 2013 02:00
Pressure boundary condition issue Vijay FLUENT 0 April 6, 2012 13:35
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 08:27
