-   OpenFOAM Programming & Development (https://www.cfd-online.com/Forums/openfoam-programming-development/)
-   -   Compile boundary condition as a new dynamic library (https://www.cfd-online.com/Forums/openfoam-programming-development/76354-compile-boundary-condition-new-dynamic-library.html)
mohanphy May 23, 2010 13:06
Dear All,
I am trying to Compile boundary condition as a new dynamic library. I following this tutorials: http://openfoamwiki.net/index.php/Tu....28OF-1.4.1.29
I have done the following steps :
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived$ svn checkout http://openfoam-extend.svn.sourcefor...bolicVelocity/
A parabolicVelocity/parabolicVelocityFvPatchVectorField.C
A parabolicVelocity/parabolicVelocityFvPatchVectorField.H
U parabolicVelocity
Checked out revision 1738.
I have downloaded it :
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived$ cd parabolicVelocity/
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity$ ls
parabolicVelocityFvPatchVectorField.C parabolicVelocityFvPatchVectorField.H
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity$ mkdir Make
Make parabolicVelocityFvPatchVectorField.H
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity$ cd Make/
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity/Make$ vim files
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity/Make$ vim options
wmake will show the following message :
openfoam@Mohan:~/OpenFOAM/openfoam-1.6/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity/Make$ wmake libso
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file parabolicVelocityFvPatchVectorField.C
SOURCE=parabolicVelocityFvPatchVectorField.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/openfoam/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/parabolicVelocityFvPatchVectorField.o
'/home/openfoam/OpenFOAM/openfoam-1.6/lib/linuxGccDPOpt/libmyBCs.so' is up to date.
lnInclude parabolicVelocityFvPatchVectorField.C parabolicVelocityFvPatchVectorField.H
Make parabolicVelocityFvPatchVectorField.dep
It has successfully creates "libmyBCs.so" in /home/openfoam/OpenFOAM/openfoam-1.6/lib/linuxGccDPOpt/libmyBCs.so
The tutorials saying that I need to add the following line in system/controlDict file: libs ("libmyBCs.so");
The problem is I don't know where is the system/controlDict file (absolute path). some one please explain me to find system/controlDict file.
Thanks & Rg
Mohan L
sihaqqi March 22, 2013 10:42
Mohan
I am after this parabolic velocity patch .C and .H. I use openFoam 2.1. the link you have given does not have these files. Can you please post these. The need is very urgent because first I have to understand them as a beginner in OpenFoam and then I shall have to convert in 1/7th power law.
I shall be grateful
regards
wyldckat March 24, 2013 15:01
Greetings sihaqqi,
They are available here: https://github.com/ogoe/OpenFOAM-1.6...bolicVelocity/
Direct links:
Best regards,
Bruno
sihaqqi March 24, 2013 19:26
Dear Bruno
Many thanks for this.
Thanks & Regards
Sihaqqi
sihaqqi March 25, 2013 03:26
Bruno
Can you please advise where I can get Make files and options from for this thing
Regards
wyldckat March 25, 2013 16:57
It's explained in the first link on this thread: http://openfoamwiki.net/index.php/Tu....28OF-1.4.1.29
nadine July 25, 2013 06:22
I don't know if I am really unlucky, but none of the links refering to parapolicVelocity are working!!!
Can someone help me and post a valid link so I can add this condition and compile it?
Thanks a lot,
Nadine
nadine July 25, 2013 09:48
Re-Hello,
Finally i found source files using this link:
https://github.com/Unofficial-Extend...eld.H.svn-base
I saved both the .C and .H in a file outside openfoam and followed the instructions givin in wiki to add my library and linked it dynamically by adding libs ("libmyBCs.so"); in my controlDict.
Than I ran the simulation but I got an error message, indicating that there is no such a boundary condition and giving me choices between the classical boundaries found in openfoam!!!
what did I do wrong and how can I fix it!
Help!
Waiting for your answers, even if it s summer time :)
Nadine,
alexeym July 25, 2013 11:17
Originally Posted by nadine (Post 441947)
Re-Hello,
Help!
Nadine,
Can you, please, post your case files?
wyldckat August 18, 2013 12:21
Greetings to all!
@Nadine: I don't know if you've fixed the problem you reported about, but here is summary and updated building instructions, based on 1.6-ext and http://openfoamwiki.net/index.php/Tu....28OF-1.4.1.29 - edit: and yes it should work for almost any version of OpenFOAM!
Run these commands:
mkdir -p $FOAM_RUN
cd $FOAM_RUN/..
mkdir parabolicVelocity
wget "http://sourceforge.net/p/openfoam-extend/OpenFOAM-1.6-ext/ci/master/tree/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity/parabolicVelocityFvPatchVectorField.C?format=raw" -O parabolicVelocityFvPatchVectorField.C
wget "http://sourceforge.net/p/openfoam-extend/OpenFOAM-1.6-ext/ci/master/tree/src/finiteVolume/fields/fvPatchFields/derived/parabolicVelocity/parabolicVelocityFvPatchVectorField.H?format=raw" -O parabolicVelocityFvPatchVectorField.H
mkdir Make
echo 'parabolicVelocityFvPatchVectorField.C'  > Make/files
echo 'LIB = $(FOAM_USER_LIBBIN)/libmyBCs'  >> Make/files
echo 'EXE_INC =  -I$(LIB_SRC)/finiteVolume/lnInclude'  > Make/options
echo 'EXE_LIBS = '  >> Make/options
wmake libso
The I used the tutorial "incompressible/simpleFoam/pitzDaily" as basis and edited the files:
  • "system/controlDict" - Added the line:
  • "0/U" - changed the BC "inlet" to this:
        inlet
            type            parabolicVelocity;
            n              (1 0 0);
            y              (0 1 0);
            maxValue        1;
            value          (0 0 0); // Dummy for paraFoam, which will NOT show a correct profile at time 0.
Then to run the case, I simply run:
blockMesh
simpleFoam
Best regards,
Bruno
wzx1989221 January 2, 2014 11:29
Dear Bruno,
I find your post very useful. Just want to know if it is possible to do the parabolic inlet in that way using OF 2.1? Or is it only applicable in OF 1.6-ext version?
Looking forward to your reply. Thank you very much.
Best regards,
Tony
wyldckat January 2, 2014 19:22
Greetings Tony,
Good question! I've updated post #10 to add a note about that.
I forgot to mention back then, but it's sort-of implied that these instructions are for any OpenFOAM version, but rely on the source code of OpenFOAM-1.6-ext. Actually, now it's foam-extend 3.0, but this boundary condition is pretty much the same ;).
Best regards,
Bruno
wzx1989221 January 2, 2014 20:02
Dear Bruno,
Thank you very much for the reply. Actually I have checked out that it works well with OF 2.1.
One thing is that I tried to use it for 3D pipe flow, but the profile turned out to be varying in only one direction like in channel. Any suggestions on making it work for pipe?
Best regards,
Tony
wyldckat January 2, 2014 20:40
Hi Tony,
Mmm... what you are looking for is a paraboloid: http://en.wikipedia.org/wiki/Paraboloid
But this boundary condition from 1.6-ext is only "parabolic" :)
The idea is that you need to modify the source code of the method "updateCoeffs()". Essentially, you need to modify these two lines of code:
// Calculate local 1-D coordinate for the parabolic profile
scalarField coord = 2*((c - ctr) & y_)/((bb.max() - bb.min()) & y_);
vectorField::operator=(n_*maxValue_*(1.0 - sqr(coord)));
Right now I don't have much time to look into this. But let me know if you don't manage to solve this by yourself. And if you are able to, do share the solution!
Best regards,
Bruno
wzx1989221 January 3, 2014 09:34
Hi Bruno,
Many thanks for the tips. I will look into that to see if I can resolve it. I will share the solution if I make it.
Regards,
Tony
vipin1431 August 6, 2015 06:20
Originally Posted by wzx1989221 (Post 468496)
Hi Bruno,
Regards,
Tony
hi tony,
I followed the above instruction to get parabolic inlet velocity and also i got same profile like i.e. variation along one direction only did you get it corrected....if yes, please help me to correct it.
regard
vipin
rudolf.hellmuth August 23, 2016 08:46
Paraboloid velocity profile on a circular patch:
    inlet
        type            codedFixedValue;
        value          uniform (0 0 0);
        redirectType    Poiseuille;
        code
            const fvPatch& boundaryPatch = patch();
            const vectorField& Cf = boundaryPatch.Cf();
            vectorField& U = *this;
            //gfunc calculates the function on decomposed patches for parallel runs.
            scalar patchArea = gSum(boundaryPatch.magSf());
            //Info << "Patch area: " << patchArea << endl;
            vector ctr = gSum(boundaryPatch.magSf()*Cf)/patchArea;
            //Info << "Patch center: " << ctr << endl;
            scalar R = sqrt(patchArea/constant::mathematical::pi);
            //Info << "Patch radius: " << R << endl;
            vector n = gSum(boundaryPatch.magSf()*boundaryPatch.nf())/patchArea;
            //Info << "Patch mean normal: " << normal << endl;
            scalar Umean = 1.0;
            forAll(Cf, i)
                U[i] = -n*2.0*Umean*(1.0 - sqr(mag(Cf[i] - ctr)/R));
            // operator==(vector(1.0, 0.0, 0.0));
This codedFixedValue BC is working for me. You can use this code to compile a PoiseuilleBC.so if you want.
I hope it can help you, :)
Rudolf
vidyadhar November 18, 2016 08:40
Paraboloid velocity profile on a square channel ?
    inlet
        code
            scalar Umean = 1.0;
            forAll(Cf, i)
Rudolf
Hello Rudolf,
I have seen your post on paraboloid profile for a circular patch.
I would like to implement paraboloid profile for a square patch, since, in my case, I have to give fully developed profile at the inlet to a square channel.
Can you help me in implementing the same.
Thanks & Regards,
vidyadhar
rudolf.hellmuth November 18, 2016 09:51
Originally Posted by vidyadhar (Post 625845)
Hello Rudolf,
I can easily help you to make this "paraboloid" if your rectangular patch is on a plane orthogonal to the Cartesian coordinates. If it is diagonal to the Cartesian coordinates, then you'd have to either give the patch orientation as input, or you'd have to figure out a way of obtaining the patch orientation with the patch data.
Try this:
// patch area
    scalar A = gSum(patch().magSf());
    // patch normal vector is the weighted mean of patch face normal
    // vectors
    vector np = gSum(patch().magSf()*patch().nf())/A;
    // patch centre is the weighted mean of patch face centres
    vector O = gSum(patch().magSf()*patch().Cf())/A;
    // local position of cell centres (referenced on the patch centre)
    scalarField pos = mag(patch().Cf() - O);
    // patch lengths on x and y directions
    scalar X = 1.0;
    scalar Y = 1.4;
    fixedValueFvPatchVectorField::operator==
    -np*vmean*2.0 *(1.0 - sqr(pos.x()/X))*(1.0 - sqr(pos.y()/Y))
I haven't tested that, it's just an idea. There are two parabolas, one on the x direction and the other on the y direction. I hope this code can help you.
Good luck!
Rudolf
vidyadhar November 18, 2016 10:07
Hello Rudolf,
Thank you for the immediate help.
I will test the code and get back to you with the outcomes.
Thanks & Regards,
vidyadhar
