take attachDetachTJunction example from 1.2 to 1.5-dev
Old   October 25, 2010, 11:26
Default take attachDetachTJunction example from 1.2 to 1.5-dev
Patricia
schmittp54 is on a distinguished road
Dear all,
I would like to get the example http://openfoamwiki.net/images/b/ba/...2-hsieh.tar.gz with documentation at
http://openfoamwiki.net/images/0/02/...hDetach.odt.gz running in OpenFoam 1.5-dev.
The example builds two executables, namely icoTopoFoamTJaunction and the utility addTJunctionModifier. In both these directories I add "-I$(LIB_SRC)/finiteVolume/lnInclude" to Make/options and I am left with a few errors:
addTJunctionModifier.C:126: error: no matching function for call to ‘Foam::attachDetach::attachDetach(const char [14], int, Foam::fvMesh&, const char [14], const char [8], const char [11], Foam::scalarField&)’
addTJunctionModifier.C:129: error: ‘class Foam::fvMesh’ has no member named ‘addTopologyModifiers’
icoTopoFoamTJunction.C:63: error: ‘class Foam::fvMesh’ has no member named ‘updateTopology’
... plus a few more that are not difficult to repair.
Which methods replace attachDetach(...), addTopologyModifiers() and updateTopology() in 1.5-dev?
If I can fix the problems in this example, I'd like to upload an update to openfoamwiki.net.
Thank you
Patricia
schmittp54 is offline   Reply With Quote
[OpenFOAM] ParaFoam instalation in OpenFoam 1.5 dev titio ParaView 2 July 25, 2010 00:24
OpenFOAM 1.5 dev LVDH OpenFOAM 98 May 5, 2010 18:01
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 13:13
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev titio ParaView 0 December 9, 2009 13:12
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
