get velocity gradient with a boundary function |
January 20, 2011, 09:08 |
Christian Lucas
Hi
I want to write a new inlet boundary condition for epsilon. For this new boundary condition, I need calculate for instance the velocity gradient ( and magSqr(symm(fvc::grad(U))) ) I know I can get the velocity field at the patch using: const fvPatchField<vector>& U = patch().lookupPatchField<volVectorField, vector>("U"); The problem is (as I understand it) that by using the code above, U is a “vector patch field”. But if I want to get the velocity gradient (using fvc::grad(U)), U must be a volVectorField. Is there a way to get the velocity of the entire grid within the boundary condition, so that I can calculate the velocity gradient and then use this result to get the velocity gradient at the patch? Thanks for the help. Christian |
August 10, 2011, 05:57 |
Hi Chris,
did you succeed? I also want to get the velocity gradient at a patch.. Thanks in advance. |
August 10, 2011, 08:36 |
Christian Lucas
I didn't looked into this subject much more and therefore didn't solve the problem. Please let me know if you do Best Regards Christian |
August 24, 2012, 13:17 |
Wei Liu
August 27, 2012, 03:11 |
Christian Lucas
no, I have not continued this work. The following is a guess only (not sure if this works or even if this is correct): I guess you need the normal BC gradient and not the fvc::grad. Look at src/thermophysicalmodelbasic/derivatedFvPatchFields/gradientEnthalpy.C as shown there, you get the surfaceNormalGradient of a fvPatchScalarfield (hope the same is true for fvPatchVectorField) with the function snGrad. Another method is to calculate the gradient by hand. You have the value at the BC and the cell value next to the BC + the distance. However, this way you do not get the surfaceNormalGradient. Kind Regards, Christian |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Calculated gradient boundary condition similar to gammaContactAngle | adona058 | OpenFOAM Running, Solving & CFD | 0 | September 26, 2007 15:23 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
