February 28, 2011, 22:36 |
Describing div terms in fvSchemes
#1 | |
Santiago Marquez Damian
Rep Power: 23 |
Hi FOAMers, I have a solver with this code:
fvVectorMatrix UEqn ( fvm::ddt(rhom, U) + fvm::div(phi, U) + fvc::div ( alpha*rhop*Vdrp*Vdrp, "div(phiVdrp,Vdrp)" ) - fvm::laplacian(mum, U, "laplacian(mum,U)") ); Code:
--> FOAM FATAL IO ERROR: keyword div(phiVdrp,Vdrp) is undefined in dictionary "/home/santiago/OpenFOAM/santiago-1.6.x/run/tankBubbles/system/fvSchemes::divSchemes" file: /home/santiago/OpenFOAM/santiago-1.6.x/run/tankBubbles/system/fvSchemes::divSchemes from line 30 to line 32. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 396. FOAM exiting Code:
divSchemes { div(phi,U) Gauss upwind; //limitedLinearV 1; div(rhop*phi,alpha) Gauss upwind; div(phiVdrp,alpha) Gauss upwind; div(phiVdrp,Vdrp) Gauss upwind; } Quote:
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
March 1, 2011, 05:57 |
Anton Kidess
Rep Power: 29 |
The divergence schemes in fvSchemes apply to convective terms like fvm::div(phi, X), but your term in the equation seems to be a simple explicit divergence of a scalar field, so why not just write it in the following way?
fvVectorMatrix UEqn ( fvm::ddt(rhom, U) + fvm::div(phi, U) + fvc::div ( alpha*rhop*Vdrp*Vdrp ) - fvm::laplacian(mum, U, "laplacian(mum,U)") ); |
March 1, 2011, 13:06 |
#3 | |
Rep Power: 23 |
Anton, I took this notation from settlingFoam, but on the other hand I'd tried you suggested with same results:
fvVectorMatrix UEqn ( fvm::ddt(rhom, U) + fvm::div(phi, U) + fvc::div ( alpha*rhop*Vdrp*Vdrp ) - fvm::laplacian(mum, U, "laplacian(mum,U)") ); Code:
--> FOAM FATAL IO ERROR: keyword div((((alpha*rhop)*Vdrp)*Vdrp)) is undefined in dictionary "/home/santiago/OpenFOAM/santiago-1.6.x/run/tankBubbles/system/fvSchemes::divSchemes" file: /home/santiago/OpenFOAM/santiago-1.6.x/run/tankBubbles/system/fvSchemes::divSchemes from line 30 to line 32. From function dictionary::lookupEntry(const word&, bool, bool) const in file db/dictionary/dictionary.C at line 396. FOAM exiting Quote:
March 1, 2011, 14:03 |
Anton Kidess
Rep Power: 29 |
Ah, you are right, looking at fvcDiv.* it is indeed possible to name even an explicit term and force usage of a certain divergence scheme instead of plainly calling surfaceIntegrate. I'm sorry I don't really have other ideas what could cause the problem. Hopefully someone else will notice this thread and have an answer.
March 1, 2011, 16:15 |
Rep Power: 23 |
Anton, the correct entry in fvSchemes is:
divSchemes { div(phi,U) Gauss upwind; //limitedLinearV 1; div(phi,alpha) Gauss upwind; div(phiVdrp,alpha) Gauss upwind; div(phiVdrp,Vdrp) Gauss upwind phiVdrp; } Regards.
Display Modes | |
Implicit treatment of advection terms and pressure correction | nikosb | Main CFD Forum | 0 | January 17, 2010 17:07 |
Using source terms | jsm | Main CFD Forum | 4 | August 20, 2009 07:44 |
Question in definition of terms in solve | titio | OpenFOAM Running, Solving & CFD | 0 | March 19, 2009 17:02 |
Source terms for additional variable transport eqn | Nandini Rohilla | CFX | 0 | February 6, 2004 14:38 |
K-Epsilon model? | Brindaban Ghosh | Main CFD Forum | 2 | June 24, 2000 05:22 |
