Variable Declaration And Initialization
Like Tree1Likes
  • 1 Post By cliffoi
Old   March 7, 2011, 09:46
Default Variable Declaration And Initialization
mart.hein is on a distinguished road
Hello everybody!
I try to read two files only if a certain condition is met. Unfortunatelly I don't know how to separately declare and initialize a volScalarField and a dimensionedScalar. My first approach did not work, because after the end of the if-conditions both variables "C" and "DC" are lost:
if (condition)
                volScalarField C
                        IOobject
                                "C",
                                runTime.timeName(),
                                mesh,
                                IOobject::MUST_READ,
                                IOobject::AUTO_WRITE
                        mesh
                // read the transportProperties file
                IOdictionary transportProperties
                        IOobject
                                "transportProperties",
                                runTime.constant(),
                                mesh,
                                IOobject::NO_WRITE
                // diffusion coefficient for the passive scalar
                dimensionedScalar& DC
                        transportProperties.lookup("DC")
How can I declare "C" and "DC" outside the if-condition and initialize them inside?
Thanks a lot for your help!
Regards
Martin
mart.hein is offline   Reply With Quote
Old   March 7, 2011, 11:46
Ivor Clifford
cliffoi is on a distinguished road
This is a C++ issue. Strictly speaking you can't optionally declare a variable. What you can do, however, is declare a pointer (or autoPtr) to the volScalarField, initialize it as NULL, and optionally set the pointer in the if-condition. Using autoPtr is the safest option since the object will automatically destruct at the end of your program.
For the dimensionedScalar I'd just declare it anyway since it uses up so little memory and use a bool to check it it has been set afterwards.
autoPtr<volScalarField> C;
dimensionedScalar DC("DC", dimless, 0);
if (condition)
    C.set(new volScalarField
        IOobject
            "C",
            runTime.timeName(),
            mesh,
        mesh
    DC = dimensionedScalar(transportProperties.lookup("DC"));
Turin Turambar likes this.
Last edited by cliffoi; March 7, 2011 at 11:51. Reason: Bad formatting of source code
cliffoi is offline   Reply With Quote
Old   March 8, 2011, 10:42
Thank you cliffoi for your help! It works now
