Pasing VolScalarField pointer to solve(), is this possible?
Old   March 15, 2011, 13:07
Default Pasing VolScalarField pointer to solve(), is this possible?
O R
arkangel is on a distinguished road
Dear FOAMERS ,
I don't think this was asked before. I am using another pakage to link against the OpenFOAM lib , I decided that the best way would be to use a pointer to the fields. so far all seems to be working well but I think (i hope I am wrong) I reach a deadlock
volScalarField *pT;
Time *pRT ;
//Function 1
void Init(){
    pT=new Foam::volScalarField
        IOobject
            "T",
            pRT->timeName(),
            *pMesh
        *pMesh
// This woks so far perfectly  i e: pT->internalField, pMesh->C(), etc
// Function 2
void solveEQ(){
  while (pRT->loop())
       solve(
                fvm::laplacian(1.0, *pT)  //DOES NOT WORK
      pRT->write();
I tried with the LaplacianFoam and I got this:
finiteVolume/lnInclude/fvmLaplacian.C:185: error: in passing argument 2 of ‘Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::laplacian(const Foam::dimensioned<Type2>&, Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&) [with Type = double, GType = double]
So the Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>& thinks that *pT is other type. In fact is volScalarField (or VolVectorField if i have to use vec filed)
Is there A way to force laplacian (or other operator) to accept my syntax
Thanks for you Help
arkangel is offline   Reply With Quote
if-loop, volScalarField comparison volker OpenFOAM 7 March 6, 2020 20:03
Problems with creating a volScalarField georlade OpenFOAM Programming & Development 4 December 4, 2016 12:31
Linearized NS euqations: how to solve them?(problem with Matrix operations..) matteoL OpenFOAM Running, Solving & CFD 0 November 18, 2009 06:58
Solve for two or more "Temperatures" Rui CFX 12 September 9, 2008 21:58
How to solve another continuum and momentum eqn? west_wing FLUENT 0 August 25, 2003 10:00
