Scalar Field Source Terms
Old   March 21, 2011, 09:45
Default Scalar Field Source Terms
Tom
tidal_Tom is on a distinguished road
I am trying to add source terms of K and epsilon using the explicitSource class found in /src/finiteVolume/cfdTools/general/fieldSources/basicSource/
I am not having much success, and I do not know if my method is correct?
I have modified the simpleFoam solver, using the SimpleWindFoam tutorial as a guide that is included with version 1.7.1.
I added the following to the header of simpleFoam.C
#include IObasicSourceList.H
added the following line at the end of createFileds.H
IObasicSourceList explicitSources(mesh)
and added mesh tools to the INC and LIBS in make/Options as in simpleWindFoam.
I have compiled the solver OK, and tried running the solver. It reads the sourceProperties file but gives an error saying 'Header not OK' when it gets to the fieldData (where the fields and source values are defined. fieldData is defined as:
fieldData
k 1.2;
epsilon 0.5;
I am not sure why this doesn't work as I have successfully run the simpleWindFoam solver that uses the actuatorDisk source.
What have I missed? Is there a better way to add source terms?
many thanks
Tom
tidal_Tom is offline   Reply With Quote
Old   March 23, 2011, 05:25
Jim Knopf
JimKnopf is on a distinguished road
Maybe you can add your source term directly into the k and epsilion or what ever equation using fvm::SuSp() oder just fvm::Su() /fvm:::SP()
it depends.
Greetz Jim
JimKnopf is offline   Reply With Quote
actuator disk, source terms
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Source Terms in Star-CCM+ mk_mat Siemens 2 March 13, 2012 08:14
Source terms in local coordinate frames CF CFX 2 August 29, 2006 02:30
Displaying Source terms Chris FLUENT 0 June 14, 2006 15:20
Source Terms Rajan CFX 1 March 14, 2005 09:26
