April 27, 2011, 09:31 |
Creating a new variable in a .C file?
Greg Givogue
Rep Power: 15 |
Hi Everyone,
I'm relatively new with OpenFOAM and C++ programming. I'd like to modify the Forces.C file to include the following calc; vector CP = sum(Md^(vf+pf))/sum(vf+pf); I believe I have to update the forces.H file as well to define CP... but I'm not sure how. When I ran wmake in the forces folder I got: forces/forces.C:469: warning: unused variable ‘CP’ make: *** [Make/linux64GccDPOpt/forces.o] Error 1 Thanks for the help! Greg |
April 28, 2011, 04:18 |
Anton Kidess
Rep Power: 29 |
A "Warning" is not the same as an "Error". Ergo, you didn't include all messages from the compiler. Anyway, it's fine to define the variable in the .C file. I believe your problem is that "^" is not the operator you'd expect - use the Foam::pow() function instead.
April 28, 2011, 09:47 |
Greg Givogue
Rep Power: 15 |
Thanks for the response. I tried a couple things and now I'm left with the following questions;
1) How do I declare CP within the scope of the write command at ln 374? 2) It doesn't seem to like my equation for CP at ln 467. I think it's the divide (/) that it doesn't like because I'm trying to divide 2 vector quantities. I think ^ is ok in this context. How would I use Foam:ow()? Thanks so much for your help! Apologies for the simple questions but I'm just starting to learn C++. Greg Last edited by Greg Givogue; April 28, 2011 at 10:13. |
April 28, 2011, 09:49 |
Greg Givogue
Rep Power: 15 |
April 28, 2011, 17:10 |
Pablo
Rep Power: 17 |
you are declarating CP just in calcForcesMoment() function, if you want to use in other functions you need to declarate at the class (forces.h), or send like an argument
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
OpenFOAM Install Script | ljsh | OpenFOAM Installation | 82 | October 12, 2009 11:47 |
[OpenFOAM] ParaView 33 canbt open OpenFoam file | hariya03 | ParaView | 7 | September 25, 2008 17:33 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
