faceI was not declared in this scope
Like Tree1Likes
  • 1 Post By marupio
Old   May 31, 2011, 08:42
Default faceI was not declared in this scope
lindstroem is on a distinguished road
Hi everyone,
I am working on the dynamicAlphaContactAngle implementation. I got a modified version by a colleague which i tried to compile. I get the error: ‘faceI’ was not declared in this scope. He works in OF 1.7.1 and I tried to compile it in both, OF 1.6-ext and OF 1.7.1 - both did not work and stopped with the same error.
I also checked the header-files he includes, but there is no difference.. I also tried to include the faceI.H but then I get errors because of multiple defintions for some variables.
Is there anyone who might has an idea? Are there any information missing?
Greetings
lindstroem is offline   Reply With Quote
Old   May 31, 2011, 09:11
David Gaden
marupio is on a distinguished road
Contact your colleague: the code is incomplete. faceI is not a class, but it is typically used as a label variable when cycling through all the faces in the mesh. e.g.:
forAll(mesh.faces(), faceI)
    // Do something
marupio is offline   Reply With Quote
Old   May 31, 2011, 09:35
Hi David,
thanks for your answer. The variable is used for a loop in a similar way as you wrote, thats correct. But what he send me is exactly what he implemented.
How would you get access to this variable if you would set up a "new" modification. To be more concrete: I am using the interFoam solver and the dynamicAlphaContactAngle BC. In the dynAlpCA implementation after the calculation of uwall I want to get the velocity gradient normal to the wall of the first cell. Therefore my colleague implemented a fct which he uses in a loop
forAll(gradUP, faceI) {etc}
where gradUP is
tensorField gradUP(size(), tensor::zero)
maybe this helps? Thank you very much in advance!
Old   May 31, 2011, 09:50
David Gaden
Hmmm... that's strange. The forAll() command is actually a macro, which does this:
forAll(objectName, indexName)
// is short for:
for (label indexName(0); indexName < objectName.size(); indexName++)
... so you see, the definition of faceI is inherent in the macro. I suspect you are not loading the header that contains the macro (UList.H, I think), or you have circular dependency in your include files.
kaifu likes this.
Old   May 31, 2011, 10:09
Hi David,
thanks again for the quick answer! I'll try to find the mistake but you already helped me a lot! Maybe I'll come back with new questions
happy foaming!
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
