nutRoughwallfunction arguments
Like Tree2Likes
  • 1 Post By case
  • 1 Post By vonboett
Old   June 17, 2011, 05:25
Default nutRoughwallfunction arguments
George
GGerber is on a distinguished road
Hi Openfoamers,
I would like to know what the last item represents in the following dictionary entry in 0/nut:
walls { type nutRoughWallFunction; Ks uniform 1e-5; Cs uniform 0.5; value uniform 1.0;}
Does it mean that nut is assigned a fixed value of 1 on the 'walls' patch throughout the entire simulation and Ks and Cs completely ignored? Or is nut assigned a value of 1 for the first time-step on the 'walls' patch?
I took a look at nutRoughWallFunctionFvPatchScalarField.C and nutRoughWallFunctionFvPatchScalarField.H, but could not see how the last dictionary entry was used.
Thank you,
George
GGerber is offline   Reply With Quote
Old   August 16, 2011, 03:28
Case Bakker
case is on a distinguished road
Hi
It seems like in OF 2.0.1 the function nutRoughWallFunction is now nutURoughWallFunction, and the arguments have changed. They are now
value
roughnessHeight
roughnessFactor
roughnessConstant
I understand what roughnessHeight refers to, but can anyone explain what exactly the other arguments change. Can't find a definitive answer anywhere in the forums.
Thanks
Case
luismsc likes this.
case is offline   Reply With Quote
Old   August 22, 2011, 06:02
Jochem
Jochem is on a distinguished road
You can also use nutkRoughWallFunction in OF2.0. I use the turbineSiting tutorial and just change Ks and Cs to my case.
Regards
Jochem is offline   Reply With Quote
Old   August 22, 2011, 06:29
Case Bakker
I tried to run one of my old cases made when I was using OF1.7.1 that uses nutRoughWallFunction, butgot an error message, giving me a list of the possible patches that are allowed, with nutURoughWallFunction being one of them. Had to change to nutURoughWallFunction, and also change the arguments.
Old   July 31, 2012, 21:03
hfs
hfs is on a distinguished road
Originally Posted by case View Post
Hi
value
roughnessHeight
roughnessFactor
roughnessConstant
Thanks
Case
Hello!
Did you get an answer?
Thanks for sharing!
hfs is offline   Reply With Quote
Old   January 29, 2013, 09:57
Albrecht vBoetticher
vonboett is on a distinguished road
I give it a try: scalarField& y = rasModel.y()[patchI]...that returns the near wall distances.
scalar dKsPlusdYPlus = roughnessHeight_/y[facei]
...is the ratio of roughness heigt to the near wall distance of patchI
dKsPlusdYPlus *= roughnessFactor_
...used for tuning this ratio to finally:
yp*dKsPlusdYPlus
...get the nondimensional roughness heigt based on the y+ value of the latest timestep.
I use roughnessFactor = 1.
roughnessConstant is only applied (as a multiplier) if the nondimensional roughness is bigger than 90, so I guess it is
about the issue of where the different regions of the wall velocity profiles are placed, viscid layer, log layer etc.
These are guesses by reading the source code. For generally understanding of the rough wall function, see the Thesis of
John O’Sullivan, February 2012, "MODELLING WIND FLOW OVER COMPLEX TERRAIN", especially eq. (2.55). He worked with OpenFOAM
y_jiang likes this.
vonboett is offline   Reply With Quote
Old   June 2, 2013, 17:21
Ksenia Kurischenko
Ksenia is on a distinguished road
Dear all,
Tell me where I can find the theoretical description of function nutURoughWallFunction?
Ksenia is offline   Reply With Quote
Old   September 17, 2014, 20:43
Gregoire Junqua
gregjunqua is on a distinguished road
Dear all
I got the same question as Ksenia
where is there any bibliography about this wall function
Gregoire Junqua
Ocean University of China
PhD Oceanography/ABL turbulence
gregjunqua is offline   Reply With Quote
Old   June 5, 2015, 09:03
Lourenço SM
lourencosm is on a distinguished road
Same question!
Anyone knows where to find info on the nutURoughWallFunction?
lourencosm is offline   Reply With Quote
nutroughwallfunction
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 64 January 6, 2024 07:13
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
