Nvd / tvd
Like Tree3Likes
  • 3 Post By santiagomarquezd
Old   October 7, 2011, 11:19
Default Nvd / tvd
Michael Buchmayr
MichiB is on a distinguished road
I was wondering if there is a major difference in the implementation of NVD and TVD schemes in OpenFOAM.
Am I right in the assumption that the only real difference between NVD and TVD schemes in OpenFOAM is the limiters?
Is it right that in OpenFOAM TVD schemes are actually nothing but special NVD schemes?
I'm having a hard time grasping how convection schemes are implemented in OpenFOAM, but as far as I understand the code, both NVD and TVD should work identically up to the point where phict ( \Tilde{ phi_{C} } ) is being calculated.
The reason why I'm asking this is that I'd like to know how the van Leer TVD (or is it NVD?) scheme works and effects the diagonal dominance of my matrix...
Michi
MichiB is offline   Reply With Quote
Old   October 7, 2011, 16:30
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Michael take a look to the document in the following link:
https://docs.google.com/viewer?a=v&p...ht7iRTTn&hl=es
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   October 10, 2011, 05:39
Michael Buchmayr
Thank you for the nice summery, Santiago. Te lo agradezco mucho!
It seems that I was wrong and TVD schemes in OpenFOAM do calculate r and not phict as I thought before.
Regards,
Michi
Old   October 30, 2015, 03:07
J.-H. Wang
f0208secretx is on a distinguished road
I have a particular question about Van Leer limiter implementation in OpenFOAM 2.4.0.
I used it to limit my divergence term by the following excerpt in fvSchemes
divSchemes
    default             Gauss linear;
    div(phi,U)          Gauss vanLeerV 2;
    div(phi,nuTilda)    Gauss limitedLinear 1;
The documentation here (http://cfd.direct/openfoam/user-guide/fvschemes/) suggested that the Van Leer limiter can be strictly bounded for scalar field. However, since I used it on U, I chose the multivariate van Leer and give it sort of an arbitrary number 2. The number 2 seems to do something, since if I don't specify this number then my solution could diverge. However, if one look into the code vanLeer.H, there does not seem to be a place for this number I specified:
(vanLeer.H)
    vanLeerLimiter(Istream&)
    scalar limiter
        const scalar,
        const scalar faceFlux,
        const typename LimiterFunc::phiType& phiP,
        const typename LimiterFunc::phiType& phiN,
        const typename LimiterFunc::gradPhiType& gradcP,
        const typename LimiterFunc::gradPhiType& gradcN,
        const vector& d
    ) const
        scalar r = LimiterFunc::r
            faceFlux, phiP, phiN, gradcP, gradcN, d
        return (r + mag(r))/(1 + mag(r));
Specifically, the red line seemed to suggest the in stream does not do anything. Whereas if one look into limitedLinear.H
(limtedLinear.H)
    limitedLinearLimiter(Istream& is)
        k_(readScalar(is))
        if (k_ < 0 || k_ > 1)
            FatalIOErrorIn("limitedLinearLimiter(Istream& is)", is)
                << "coefficient = " << k_
                << " should be >= 0 and <= 1"
                << exit(FatalIOError);
        // Avoid the /0 when k_ = 0
        twoByk_ = 2.0/max(k_, SMALL);
    scalar limiter
        const scalar cdWeight,
        const vector& d
    ) const
        return max(min(twoByk_*r, 1), 0);
The instream was used and a blending factor was considered (bounded between 0 and 1).
I am very confused now if van leer takes any argument and how do I specify it? Further, if I specify a strict bound, how can one choose such a number... it does not make sense to me that one could set an absolute bound before solving the system, otherwise why do you need the solver for...
f0208secretx is offline   Reply With Quote
Old   October 31, 2015, 16:12
J.-H. Wang
any ideas?
Old   November 5, 2015, 08:18
Davi Barreira
davibarreira is on a distinguished road
Why are you trying to bound the U (velocity)? The use of bounded values with vanLeer is usually for scalars who have limited values, such as volume fraction that has to be between 0 and 1. For vectors, you are using vanLeerV, so I would guess that it makes no sense to prescribe a limiter such as 2, and for such reason it does nothing.
davibarreira is offline   Reply With Quote
Old   June 2, 2021, 04:54
Youjiang Wang
wyj216 is on a distinguished road
By reading the code, I have no problem to understand the implementation of TVD. However, for the NVD, e.g. Gamma scheme, it seems that the limiter for phict > 1 is not correct. When phict > 1, upwind should be used, which means the limiter should be 0. But the code would gave a limiter having value of 1. Does anyone have the same confusion?
//position: src/finiteVolume/interpolation/surfaceInterpolation/limitedSchemes/Gamma/Gamma.H
scalar limiter
         const vector& d
     ) const
         scalar phict = LimiterFunc::phict
         return min(max(phict/k_, 0), 1);
wyj216 is offline   Reply With Quote
Old   June 6, 2021, 15:19
s.v
s.v
s.v is on a distinguished road
Hi Youjiang:
Few years ago I looked a little bit at some OpenFOAM convection schemes and I think the Gamma scheme implementation is bugged in OpenFOAM (atleast it was in the version I was using).
I do not remember all the details of my work at this point -- but I do talk about a bug in the Gamma scheme in my PhD thesis "A LARGE EDDY SIMULATION STUDY OF THE EFFECTS OF WIND AND SLOPE ON THE STRUCTURE OF A TURBULENT LINE FIRE" (it can be downloaded from here: https://drum.lib.umd.edu/handle/1903/21883) -- please see pages 31 and 32 in my thesis -- I think I am talking about the same issue that you are mentioning in your post.
There is more information about convection schemes in my thesis that you might find interesting -- for example the Gamma and the limitedLinear schemes are practically identical at lower values of k (see Figure 2.10 in my thesis), the limitedLinear scheme is incorrectly described on the NVD diagram in the OpenFOAM documentation (see Figure 2.8 in my thesis).
I am thinking maybe I should create a small post here on cfd-online and summarize my work on OpenFOAM convection schemes -- that might be useful for other OpenFOAM users. I think my thesis goes a little bit beyond this very helpful OpenFOAM based book by Moukalled et al. https://www.springer.com/gp/book/9783319168739, in terms of OpenFOAM convection schemes.
I hope it helps a little bit.
Cheers ....
s.v is offline   Reply With Quote
Old   July 21, 2021, 05:27
Youjiang Wang
Originally Posted by s.v View Post
Hi Youjiang:
Cheers ....
Thanks for your reply, salman, I would have a look at your thesis. It seems that it will help a lot.
Interpolation in OpenFoam srinath OpenFOAM Programming & Development 7 June 6, 2021 15:52
TVD ... Questioner Main CFD Forum 1 June 7, 2006 08:54
4th and 5th Order TVD Runge-Kutta Methods saygin Main CFD Forum 2 January 30, 2006 11:45
TVD TVD Main CFD Forum 0 November 17, 2005 11:25
TVD Schemes Matt Umbel Main CFD Forum 1 January 25, 2000 04:21
