Workings of setValuesFromList
Like Tree1Likes
  • 1 Post By lrunber
Old   December 30, 2011, 20:48
Default Workings of setValuesFromList
lazio
lrunber is on a distinguished road
Dear Foamers,
I am trying to understand the function setValuesFromList which is in fvMatrix.C lines 181-267 in OF 2.1.0.
As I understand the core is executed in lines 207 & 208:
        psi[celli] = value;
        source_[celli] = value*Diag[celli];
which sets the source vector equal to the diagonal times the value specified. This makes sense and I can understand.
However I fail to fully grasp lines 220-232, i.e.,
             if (symmetric())
                        if (celli == own[facei])
                            source_[nei[facei]] -= upper()[facei]*value;
                        else
                            source_[own[facei]] -= upper()[facei]*value;
                        upper()[facei] = 0.0;
* What is the meaning of upper()?
* What is the meaning of "source_[nei[facei]] -= upper()[facei]*value", does this set the source vector of the neighbor cells, and why does it only subtract and not set?
* Would it not be suffice to just set the neighbor matrix coefficients (a_N) to zero?
Thank you very much, all input is very much appreciated.
lrunber is offline   Reply With Quote
Old   December 31, 2011, 11:17
Retired Super Moderator
Bruno Santos
Greetings lrunber,
I'm not familiar with this part of the code of OpenFOAM, but since we are near the end of 2011 and beginning of 2012 (and if will be like last year), the experts on this subject won't come back for a another few days.
So, based on the following information:
  • Source: http://foam.sourceforge.net/docs/cpp....html#_details
    lduMatrix is a general matrix class in which the coefficients are stored as three arrays, one for the upper triangle, one for the lower triangle and a third for the diagonal.
    Addressing arrays must be supplied for the upper and lower triangles.
  • The outer if block checks for symmetry, therefore the contents are meant to be related only to symmetry.
Should be the reference to the Upper matrix of a symmetric matrix. This way only half of the matrix needs to be stored.
In OpenFOAM, operators sometimes don't do what we expect them to do. Check the source code when in doubt: http://foam.sourceforge.net/docs/cpp...ce.html#l00215
By what I can deduce from that set of code, for whatever reason, that "upper" matrix seems to only contain weights. That is why the set value is weighed-in with the upper value, then neutralized so it won't be used in future iterations.
This should get you going forward, at least until someone more experienced can answer you!
Best regards,
Bruno
Old   December 31, 2011, 13:30
lazio
Thank you very much Bruno!
May I also take this opportunity to wish you a fantastic 2012
I think I may have figured it out, I will write out my understanding and if someone could please just comment on the correctness..
The discretized FVM equation for each cell can be written out as:
a_p \phi_p + \sum a_n \phi_n = r (Eq. 1)
In the ldumatrix these terms correspond to:
a_p = diag()
a_n = upper() and lower()
r = source_
and the solution variable corresponds to:
\phi = psi_
To "force" the solution in the specified cells (cellLabels) to the specified values (values), the following operations are performed on the matrix for each of the concerned equations:
\phi_p = value (line: 207)
r = value * a_p (line: 208)
a_n = 0.0 (line: 231 or 244 & 245, depending on matrix symmetry)
This results in the trivial solution of Eq. 1 i.e.,
a_p \phi_p + \sum 0.0 * \phi_n = a_p \phi_p
However, there remains the important aspect of the influence of the fixed cells on their neighbor cells and setting a_n = 0.0 removes this influence (since it is zero'd!). This is where I am very impressed with this code (if I understand it correctly), since before the zero'ing of a_n, the influence of the concerned cells is added to neighbors by modifying the source term for the neighboring cells (r^* ) using the old a_n value before setting it to zero.
r^* = r^* - \sum a_n * value (lines 224 & 228 or 237 & 241 depending on symmetry)
I hope my understanding is correct. Thanks again Bruno for putting me on track.
wyldckat likes this.
question about uds tanven FLUENT 2 July 5, 2015 11:22
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
CHANNEL FLOW: a question and a request Carlos Main CFD Forum 4 August 23, 2002 05:55
question K.L.Huang Siemens 1 March 29, 2000 04:57
