March 19, 2012, 03:11 |
Writing IOdictionary to user-defined folder
#1 | |
Arne Stahlmann
Hi foamers,
I would like to create a specific (new) IOdictionary to store some values and save it in a used-defined folder. Generating the IOdictionary itself works, saving it to the folder does not fully work. I so far did Quote:
So I guess I have to register this boundaryField folder somehow? Btw: This is done in a post-processing tool, so not during runtime of a solver. Arne |
March 20, 2012, 02:14 |
#2 | |
Mark Olesen
Rep Power: 40 |
If you *really* know what you are doing, and want to bypass the usual mechanisms, you can also experiment with the following constructor form ... but you are really on your own here (there is a large potential of creating something stupid if you are not careful): Code:
//- Construct from path, registry, io options // Uses fileNameComponents() to split path into components. IOobject ( const fileName& path, const objectRegistry& registry, readOption r=NO_READ, writeOption w=NO_WRITE, bool registerObject=true ); |
March 20, 2012, 02:31 |
Arne Stahlmann
Thanks Mark,
maybe its not that complicated/bad as it sounds. The only reason of using an IOdictionary is that I did not know a better structure for storing several List<vectorField> object entries within one file (including header). It does not really matter where this dictionary is saved, but I just want to keep the structure clear. Therefore a subfolder with several dictionaries in it. This came to my mind because the folder structure created by the sample tool (folder "surfaces" with subfolders) is similar and I want to create something like that. Arne |
June 16, 2021, 04:04 |
Tushar Survase
Rep Power: 5 |
fileName writeDirectory = "constant/boundaryField";
IOdictionary vectorDict ( IOobject ( "a", runTime.constant(), writeDirectory, runTime, IOobject::NO_READ, IOobject::AUTO_WRITE ) ); vectorDict.Foam::regIOobject::write(); This will work. |
User Defined function for scalar gradient caculation with Star ccm+ V4 | coolio | STAR-CCM+ | 4 | August 11, 2023 05:38 |
Creating new user defined material | Vidya | FLUENT | 4 | August 26, 2013 09:26 |
user defined sourcen term | xck1986 | CFX | 1 | July 8, 2010 08:35 |
user defined turbulence model | manuutin | STAR-CD | 5 | October 14, 2009 05:29 |
Usage of user defined functions | Gowrish | FLUENT | 1 | October 26, 2005 07:44 |
