Solving coupled equations in one domain
Old   February 16, 2012, 10:31
Default Solving coupled equations in one domain
jdv
Jonas Due Vesterheden
jdv is on a distinguished road
I need to solve a steady state problem for two scalar fields on the same domain. The governing equations are:
a and b are coupled by the bounday conditions:
Where n is the outward surface normal.
I have tried creating a solver that simply uses
solve(fvm::laplacian(a) + k*k*a);
solve(fvm::laplacian(b) + k*k*b);
and using groovyBC for the boundary conditions, but this of course does not work since the coupling is not taken into consideration.
What would be the best approach for solving these equations? I have found coupledFvScalarMatrix in openfoam-extend, would that be applicable to my problem? Are there any other methods I could try?
Best regards,
Jonas
jdv is offline   Reply With Quote
Old   February 17, 2012, 13:51
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Jonas,
You could look at solidDisplacementFoam which solves for T and D (on the same mesh), where there is one way coupling.
Or you could look at icoFsiFoam which solves for U and D (on different meshes), where there is two way coupling.
Essentially both of these solve the equations like you did except they have an outer correction loop allowing the whole system to converge. Also you might need to relax your 'a' and 'b' after solving to achieve better convergence.
Philip
bigphil is offline   Reply With Quote
Old   April 2, 2012, 11:10
Gilles De Neyer
gdeneyer is on a distinguished road
I post in this topic as I think I have to use the coupledMatrix :
I would like to solve to different set of equation in two parts of my domain:
and a the interface I would like to impose
U_left = U_right
p_left = p_right
and then classics inlet/outlet condition for the entire domain. I have checked the cases for Fluid-Structure interaction but it's not useful for my case. I don't know how I can impose a boundary condition taking into account the solution of the other problem at each time step :-s
If someone got a solution I would be really glad to hear it
gdeneyer is offline   Reply With Quote
Old   April 2, 2012, 12:24
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Hi
You may need to loop the solution of your equations while updating coefficients for your BCs. Have a look at the SIMPLE algorithm: http://openfoamwiki.net/index.php/Th...hm_in_OpenFOAM
Best regards,
Hisham El Safti
Hisham is offline   Reply With Quote
Old   April 2, 2012, 13:30
Gilles De Neyer
Thanks you for your answer Hisham
I'm not sure I got this,
you mean :
solving for U_left ;
impose U_right.boundaryfield[patchlabel] = U_left.boundaryfield[patchlabel];
solving for U_right;
U_left.correctboundarycondition;
U_right.correctboundarycondition;
My problem is that using the correctboundarycondition will give me bad answer anyway as there is no condition to say "the inlet velocity is the same as the outlet velocity from domain 1 which has been calculated with nodes of domain 1 AND domain2)
Is my point understandable ? :-) it's quite hard to explain in a few words ...
Old   April 2, 2012, 14:01
Hisham's Avatar
Hisham Elsafti
Hi gdeneyer,
Take a look at the cyclic boundary condition. It is supposed to reduce repetitive geometries by imposing similar continuity conditions on two separate patches. Nevertheless, I am not sure whether it would work for your case!
If your first domain solves and passes values (in a one-way fashion) to the other domain, then why not do the simulations of both domains separately?
Another idea would be to treat both domains in the same fashion as porous media in OF so you would not need any additional work at the two domains interface (they would actually be one domain with extra terms in the PDEs turned on for one domain and off for the other).
Best regards,
Hisham El Safti
you mean :
Old   April 2, 2012, 14:29
Gilles De Neyer
Well, it seems to me that it would be exactly what I'm looking for, I'm gonna look into that direction.
Thanks you for your help !
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
