April 11, 2012, 14:51 |
full cell stencil with parallelisation
Matthias Walter
Rep Power: 17 |
I'm trying to get the cell centered values surrounding an arbitrary given cell in a certain volField, i.e. volVectorField U. First I have used a search algorithm that finds for a given cell all neighbour cells and returns the cell values but all in all, it's not working in parallel due to missing diagonal dependencies in the mesh. Afterwards, I got a hint that the extendedStencil stuff could possibly be used for this. So I'm trying to make it work but ...hmm ... no success till now (especially not in parallel). Code:
CPCCellToCellStencil wideStencil(mesh()); forAll(mesh().C(), lcellI) { const labelList& cell27Stencil=wideStencil[lcellI]; forAll(cell27Stencil, cellI) { // now it becomes tricky ... // that's not working since the global addressing of the volField is wrong Pout << " center value: " << unFilteredField().[cell27Stencil[cellI]] << endl; } } So I would be grateful for suggestions how to solve this messy problem! Maybe somebody has already done this or has some experience with the stencil stuff. Best regards Matthias |
April 13, 2012, 11:48 |
Kyle Mooney
Rep Power: 17 |
Hi Matthias,
While I don't have much experience in this matter, there is an extended stencil implementation of leastSquares here: /OpenFOAM/OpenFOAM-1.6-ext/src/finiteVolume/lnInclude/extendedLeastSquaresVectors.C You might be able to gain some insight if you haven't already checked it out. Good luck, Kyle |
FvMatrix coefficients | shrina | OpenFOAM Running, Solving & CFD | 10 | October 3, 2013 14:38 |
extended cell stencil | tomislav_maric | OpenFOAM Programming & Development | 4 | February 1, 2012 09:38 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
