simpleFoam for laminar pipe parabolic flow
Old   April 15, 2012, 10:48
Default simpleFoam for laminar pipe parabolic flow
Goutam Saha
Goutam is on a distinguished road
Dear All,
I am trying to add parabolic flow at the inlet. The p and U files are given below. I am not getting satisfactory results. Can anyone tell me where is the problem.
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type fixedValue;
value uniform 0;
outlet
type zeroGradient;
Walls
type zeroGradient;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type codedFixedValue;
value $internalField;
redirectType ramp;
code
scalar U_0=0.001934;
scalar r=0.02595;
fixedValueFvPatchVectorField myPatch(*this);
forAll(this->patch().Cf(),i)
myPatch[i]=vector(2*U_0*(1-Foam:ow(this->patch().Cf()[i].x(),2)/pow(r,2)),0,0);
operator==(myPatch);
outlet
type zeroGradient;
Walls
type fixedValue;
value uniform (0 0 0);
Goutam is offline   Reply With Quote
Old   April 24, 2012, 18:38
kallone
kallone is on a distinguished road
Hi Goutam,
I am also modeling laminar 3D pipe flow. I've found that a poor quality mesh can lead to results that do not match the analytical solution. You may want to try refining your mesh and see if that helps. Also I would suggest switching your inlet and outlet pressure BCs.
kallone is offline   Reply With Quote
Old   April 25, 2012, 07:08
Goutam Saha
Dear Kallone,
I have checked my mesh and its fine. Since, I am using parabolic BC at the inlet, so I am expecting the same pattern throughout the length and constant centerline velocity profile. I am not getting this at all. I didn't find the problem. Did you get the correct result ???
Thanks.
Goutam
Old   April 25, 2012, 09:02
Goutam Saha
I am using simpleFoam solver. Please see the attached file. I attached all the files that is necessary to run the problem.
Thanks
Goutam
Old   April 25, 2012, 09:08
April
april0100 is on a distinguished road
Hi Goutam,
I am using a constant velocity profile at the inlet but obtain correct results for this scenario using SimpleFoam.
Have you tried switching the pressure BCs? That is, specify p = 0 at the outlet and zero gradient at the inlet. You cannot fix both the velocity and the pressure at the inlet at the same time.
april0100 is offline   Reply With Quote
Old   April 25, 2012, 09:16
Goutam Saha
hi april
I have used a constant velocity at the inlet and I also got the correct results using simpleFoam. I will change the pressure Bcs and hope it will work !!!
Problems with simpleFoam with flow in pipe fsalvucci OpenFOAM 6 April 17, 2012 08:31
simpleFoam Blows up with Parabolic Inlet Pipe Flow swahono OpenFOAM 0 December 6, 2010 19:37
Turbulence intensity in fully devloped pipe flow - Reference Shocktrain Main CFD Forum 0 October 14, 2010 06:58
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Turbulence in a pipe flow JM Main CFD Forum 4 December 21, 2006 04:04
