Pressure convergence problems with directMapped |
March 14, 2012, 07:02 |
Arve
Rep Power: 14 |
I am trying to simulate an infinite corrugated pipe using a single corrugation and a wedge. The solver is rhoPimpleFoam with LES Smagorinsky. The mesh is attached. checkMesh reports no errors with
Mesh non-orthogonality Max: 39.808437694 average: 4.9037417816 Max skewness = 0.5954216663 OK. Code:
inlet { type directMappedPatch; nFaces 37; startFace 8051; sampleMode nearestPatchFace; samplePatch outlet; offset (0.0029 0 0); //sampleMode nearestCell; //sampleRegion region0; //samplePatch none; //offsetMode uniform; } U: Code:
inlet { type directMapped; value uniform (10 0 0); interpolationScheme cell; setAverage true; average (10 0 0); } outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } Code:
inlet { type zeroGradient; } outlet { type waveTransmissive; field p; phi phi; rho rho; psi psi; gamma 1.3; fieldInf 1e5; lInf 1; value uniform 1e5; } Any help would be greatly appreciated. |
March 15, 2012, 04:44 |
Arve
Rep Power: 14 |
If anyone is interested in running my case for themselves, I have uploaded my whole case with mesh.
http://dl.dropbox.com/u/39254711/case.zip |
March 16, 2012, 04:56 |
Arve
Rep Power: 14 |
Did you get that error with my case setup? I am running OF 2.0. The solver I am using for the pressure is GAMG, so that should not give an error.
EDIT: responded to a post here which has since been removed. Last edited by Taltan; March 16, 2012 at 08:21. |
April 27, 2012, 03:59 |
Klio
Rep Power: 14 |
Hello!
Im trying to do a multi Region sim and now I have to set Bc. It is not very clear for me what compressible::turbulentHeatFluxTemperature does and how I can change my BC so that OF don't want so cast my bc and how i can define an energy heatsource on my solid patch. Can you help me with my problem? |
cyclic, directmapped, infinite, pipe, pressure |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
convergence in unstedy problems | hedge | FLUENT | 0 | November 27, 2007 09:24 |
Please guide for pressure convergence | Nav | Main CFD Forum | 2 | May 26, 2003 03:34 |
Convergence problems | Emilien | FLUENT | 3 | May 3, 2002 08:43 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
