Lookup transportproperties from BC
Like Tree2Likes
  • 1 Post By michielm
  • 1 Post By alberto
Old   April 28, 2012, 05:57
Default Lookup transportproperties from BC
Michiel
michielm is on a distinguished road
I am currently adapting the dynamicAlphaContactAngle BC and I want to access transportProperties. I found online (http://albertopassalacqua.com/?p=947) that the following piece of code should take care of that:
// Extract the dictionary from the database
const dictionary& transportProperties = db().lookupObject<IOdictionary>
 "transportProperties"
// Exctract subdictionary from the main dictionary
dictionary mySubDict
 transportProperties.subDict("mySubDict")
// Extracting scalar value
dimensionedScalar myScalar(mySubDict.lookup("myScalar"));
However, if I compile the library I get the following error message:
/fhome/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C: In member
function `const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const
[with Type = Foam::IOdictionary]':newDynAngleFvPatchScalarField.C:153:   instantiated from here
/fhome/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C:130:
error: cannot dynamic_cast `(const Foam::Time*)((const Foam::objectRegistry*)this)->Foam::objectRegistry::time_'
(of type `const struct Foam::Time*') to type `const class Foam::objectRegistry*' (source is a pointer to incomplete type)
make: *** [Make/linux64GccDPOpt/newDynAngleFvPatchScalarField.o] Error 1
I don't really understand the error message. Does anyone know what could be the problem here?
atulkjoy likes this.
michielm is offline   Reply With Quote
Old   April 29, 2012, 01:07
Alberto Passalacqua
Hi Michiel,
I have the code compiling in one of the boundary conditions I implemented (posted below as example). I think the error is somewhere else
    const dictionary& kineticTheoryProperties = db().lookupObject<IOdictionary>
        "kineticTheoryProperties"
    dictionary phaseaDictionary
        transportProperties.subDict("phasea")
    dimensionedScalar rhoa(phaseaDictionary.lookup("rho"));
Could you post your code so that who reads can look at it?
Best,
Alberto Passalacqua
Last edited by alberto; April 29, 2012 at 01:07. Reason: removed redundant signature
Old   April 29, 2012, 03:11
Michiel
Hi Alberto,
Thanks for the quick response.
If I comment out this piece of code, the library compiles as it should (and can be used with interFoam). So maybe there is something earlier in my code that has a weird interaction with the lookup piece?
Anyway, the rest of the member functions section (which is the only part I touched), is added below:
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
Foam::tmp<Foam::scalarField>
Foam::newDynAngleFvPatchScalarField::theta
    const fvPatchVectorField& Up,
    const fvsPatchVectorField& nHat
) const
    if (uTheta_ < SMALL)
        return tmp<scalarField>(new scalarField(size(), theta0_));
    const vectorField nf(patch().nf());
    // Calculated the component of the velocity parallel to the wall
    vectorField Uwall(Up.patchInternalField() - Up);
    Uwall -= (nf & Uwall)*nf;
    // Find the direction of the interface parallel to the wall
    vectorField nWall(nHat - (nf & nHat)*nf);
    // Normalise nWall
    nWall /= (mag(nWall) + SMALL);
    // Calculate Uwall resolved normal to the interface parallel to
    // the interface
    scalarField uwall(nWall & Uwall);
    // MM: Define result as a new 0 scalarField to fill with the new theta later on
    scalarField& result = *new scalarField(uwall.size(),scalar(0));
    // MM: IMPORTANT: theta0_ is in degrees! Therefore: define pi and
    //               use that to recalculate theta0_
    scalar pi(4.*atan(1.)) ;
    scalar theta0_rad(theta0_/180.0*pi);
152 //MM: trying to access transport properties for the value of nu
153 const dictionary& transportProperties = db().lookupObject<IOdictionary>("transportProperties");
155 // Exctract subdictionary from the main dictionary
156 dictionary mySubDict
157 (
158     transportProperties.subDict("phase1")
159 );
161 // Extracting scalar value
162 dimensionedScalar myScalar(mySubDict.lookup("nu"));
164 Info << "this should be nu:" << myScalar << endl;
    //MM: loop over all uwall[i], because power of scalarField is not allowed
    // i checked with Matlab that the implementation yields the correct numerical answers
    forAll(uwall,i)
        result[i] = 180.0/pi*pow(max(pow(theta0_rad,3.0)-40.6098*uwall[i],0),1./3.);
    //MM: The original equation
    // return theta0_ + (thetaA_ - thetaR_)*tanh(uwall/uTheta_);
	//MM: Return of the new calculation
    return result;
I have indicated the line numbers in my code, according to the error message the error is in line 153.
Is there any change that it is a version issue?! I'm using OF-1.7.1 (as you might have seen already in the error message)
Cheers,
Old   April 29, 2012, 03:53
Alberto Passalacqua
I modified the BC in ~/OpenFOAM/OpenFOAM-2.1.x/src/transportModels/twoPhaseInterfaceProperties/alphaContactAngle/dynamicAlphaContactAngle/ including your exact lines of code, and it compiles. I am not sure what's going on in your code.
Alberto Passalacqua
Old   April 29, 2012, 06:48
Michiel
Thanks for trying that!
Since the newDynContactAngle was a separately compiled library (copied from the dynamicAlphaContactAngle) I decided to try putting the piece of code directly in the dynamicAlphaContactAngle.C file and recompile it. Just to see whether I messed up when copying and recompiling the new library.
Probably I didn't, because I get the same error message again. So either my openfoam installation has some error somewhere, or there is a difference between 1.7.1 and 2.1.x that causes the problem.
I think I'll switch to 2.1.x. In both cases I mention above I have to recompile OpenFOAM so I might as well. I haven't done much custom coding yet so working with the newest version will help me in the future anyway.
Thanks again for the help, it's much appreciated!
transportProperties: CrossPowerLawCoeffs...? klausb OpenFOAM Running, Solving & CFD 2 March 25, 2016 14:45
Dynamic Viscosity at transportproperties dictionary NickolasPl Main CFD Forum 0 June 2, 2011 14:06
Convergence on anisotropic tetahedral meshes pbo OpenFOAM Running, Solving & CFD 12 December 14, 2010 11:59
Error with 'vanAlbada' scheme Julian K. OpenFOAM Running, Solving & CFD 0 June 18, 2009 09:31
Buoyancydriven cavity flow anita OpenFOAM Running, Solving & CFD 3 March 26, 2008 10:24
