Warning/Error message when running OF21 in cluster ROCKS |
May 10, 2012, 06:12 |
Hi all!
After the invaluable help received from this forum in the last couple of weeks, I have been able to submit jobs in parallel in a ROCKS cluster in parallel from the front-end. My jobs are running and I'm getting the same results as before in another machine (they took a bit longer 'cause of the size of the machine). I am getting a warning/error message in the "*.o####" file that is created from any job run. The message is the following: [compute-1-8.local:12970] mca: base: component_find: unable to open /share/apps/centFOAM/OpenFOAM/ThirdParty-2.1.0/platforms/linux64Gcc/openmpi-1.5.3/lib/openmpi/mca_mtl_psm: libpsm_infinipath.so.1: cannot open shared object file: No such file or directory (ignored) Repeated as many times as processors are being used. Any comments on it? Thanks! |
OF21 not running when submitted to queue in ROCKS cluster | aerospain | OpenFOAM Installation | 5 | May 7, 2012 03:41 |
Fluent on Rocks 5.4.3 Cluster | kami146 | FLUENT | 0 | March 29, 2012 03:51 |
Rocks and linux for fluent cluster | Far | FLUENT | 2 | March 2, 2012 09:31 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
