AMI matchTolerance
Old   May 21, 2012, 05:48
Default AMI matchTolerance
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
i'm getting errors for an AMI fan simulation. At a given timestep, the weights of the AMI reaches 0. I saw that some guys here already faced this problem, but I couldn't find any clear suggestion to avoid it.
To start to investigate this problem I try to understand the matchTolerance value in polymesh/boundary file. Can you explain me it's function? It's a geometrical tolerance for the two sides of the AMIs? In the case described above, should I increase or decrease it?
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
ami, matchtolerance, weight
Problem using AMI vinz OpenFOAM Running, Solving & CFD 298 November 13, 2023 08:19
Problems using reconstructPar on a case involving AMI Kaskade OpenFOAM Running, Solving & CFD 38 September 30, 2020 06:36
OpenFOAM 2.1.x - AMI (Arbitrary Mesh Interface) philippose OpenFOAM Running, Solving & CFD 39 March 17, 2017 09:52
propeller tutorial using AMI in OF v2.1.0 impecca OpenFOAM Pre-Processing 6 May 9, 2016 10:22
Problem in AMI ysh1227 OpenFOAM Running, Solving & CFD 9 March 23, 2015 09:43
