Running a very large parameter range with OpenFOAM-2.1.x |
October 15, 2012, 22:58 |
Nishit Joseph
Rep Power: 15 |
Hi OF Users!
I want to run a wide range of parameters for a case that I am studying. When using fluent, I used to work with Python to create the journal files put them in seprate directories and then submit the job (work is done on a HPC). I would like to do the same in OpenFOAM-2.1.x. I have seen some examples in python wrapers called pyFoam now pythonFlu. Unfortunately I am not able to compile pythonFlu against OF-2.1.x. The binaries are for python24 which make it tough for me to work on my laptop (to then later submit to the HPC). I use ArchLinux and there is no offical Python24. Is there any tool that I can use to create OF cases. Cheers! Nishit |
October 16, 2012, 04:24 |
#2 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
For an example on a parameter variation see http://openfoamwiki.net/index.php/Co...eter_Variation (while writing I realised that the example still uses the pre-1.5 convention for utility-calling. But it should give you an idea)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
OpenFOAM 2.1.x - AMI (Arbitrary Mesh Interface) | philippose | OpenFOAM Running, Solving & CFD | 39 | March 17, 2017 09:52 |
Eureka, OpenFoam 1.5 is running on OpenSUSE11.1 | Ahmed | Main CFD Forum | 0 | March 7, 2009 22:20 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Running OpenFOAM | Sean | Main CFD Forum | 1 | April 8, 2008 13:26 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 13:50 |
