About the reactingFoam solver
Like Tree1Likes
  • 1 Post By mturcios777
Old   June 3, 2012, 23:45
Question About the reactingFoam solver
Qingang Xiong
Qingang Xiong is on a distinguished road
Dear OF members,
I am learning the code of reactingFoam. I found that in the reactingFoam.C there is "#include rhoEqn.H". I just want to know where is this header file? In addition, at where the compressivity "psi" get its value? I found that psi = thermo.psi(), but how the psi_ get its value? These two issues made me confused. Thank you for reply!
Qingang Xiong is offline   Reply With Quote
Old   June 4, 2012, 03:16
Olivier
olivierG is on a distinguished road
hello,
You will find rhoEqn.H in src/finiteVolume/cfdTools/compressible/, as rhoEqn is shared by other solver. (i guess you and me would have liked a link instead).
Psi come from your thermoType, that why you get "psi = thermo.psi()". (C++ stuff to save memories ...)
regards,
olivier
olivierG is offline   Reply With Quote
Old   June 4, 2012, 12:51
Qingang Xiong
Originally Posted by olivierG View Post
hello,
regards,
olivier
Dear olivier,
Thank you very much for your reply! I have found the "rhoEqn.H". But for the psi(), I know it is positioned in the class "basicThermo" and it is used to access the variable "psi_". But in "basicThermo.C" I found that "psi_" needs not to read data, so where for the program gives value to "psi_"? Thanks.
Old   June 4, 2012, 12:58
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
psi() is an access function to get a reference to the private member psi_ of the thermo class. As an example, look at the top level thermo classes of psiThermo and rhoThermo to see the differences.
mturcios777 is offline   Reply With Quote
Old   June 5, 2012, 09:58
Qingang Xiong
Dear mturcios,
Thank you for your help. I understand that psi() is an access function to psi_ and rho = p*psi() in psiThermo. Whether it means that psi_ will get value automatically with 1/(RT)? I found the combustionModels is really complex and related to thermoPhysics models which is also very complex. I think you are good at these so kindly thanks!
Old   June 5, 2012, 12:28
Marco A. Turcios
Have a look in $FOAM_SRC/thermophysicalModels/basic/psiThermo/hsPsiThermo/hsPsiThermos.C. There you will see all the allowed types for hsPsiThermo. psi is calculated from the equation of state, so the calculation of psi depends on which equation of state you have selected. The code for the different equations is found in $FOAM_SRC/thermophysicalModels/specie/equationOfState.
For example, for perfectGas (in equationOfState/perfectGas/perfectGasI.H), psi = 1/(R()*T). Have a look at the section on thermophysical models to see how the specification of thermo works.
wenxu likes this.
Old   June 5, 2012, 12:35
Qingang Xiong
Dear mturcios,
I understand now. Thank you very much! Can I have your email? May be we can discuss about OpenFOAM directly.
Is it possible to accelerate the ode solver of reactingFoam? pajofego OpenFOAM Running, Solving & CFD 2 August 10, 2014 05:38
HELP!!! (ReactingFoam) vianne OpenFOAM 3 March 14, 2010 19:17
ReactingFoam solver muthukaalai OpenFOAM Running, Solving & CFD 1 June 16, 2008 13:36
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
ReactingFoam solver restart gcollecutt OpenFOAM Running, Solving & CFD 0 August 9, 2007 05:30
