rhoCentralFoam - Problem high difference pressure |
June 11, 2012, 09:29 |
I'm new to OpenFoam (2.1.0). I try to simulate underexpanded axisymmetric supersonic flow of Argon. I used tutorial model : LadenburgJet60Psi.My simulation seems to work when difference between inlet and chamber pressure is small (factor of 10). But when this ratio becomes of the order of 1000, I get the famous error "floating exception point". I attempt different parameters, boundaries and I don't success to find where is my error. Can Openfoam solve this kind of problem ? Thank you and sorry for my English. Here my parameters : BlockMesh : convertToMeters 0.001; vertices ( ( 0 0 0) (18 0 0) ( 0 1 -0.008726655121) (18 1 -0.008726655121) ( 0 9 -0.017453310242) (18 9 -0.017453310242) ( 0 1 0.008726655121) (18 1 0.008726655121) ( 0 9 0.017453310242) (18 9 0.017453310242) ); blocks ( hex (0 1 3 2 0 1 7 6) (60 10 1) simpleGrading (1 1 1) hex (2 3 5 4 6 7 9 8) (60 10 1) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type patch; faces ( (0 2 6 0) ); } outlet { type patch; faces ( (1 3 7 1) (3 5 9 7) ); } freestreamInlet { type patch; faces ( (2 4 8 6) ); } freestream { type patch; faces ( (4 8 9 5) ); } wedge1 { type wedge; faces ( (0 2 3 1) (2 4 5 3) ); } wedge2 { type wedge; faces ( (0 1 7 6) (6 7 9 8) ); } ); mergePatchPairs ( ); ThermoPhysicalProperties : thermoType ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>; mixture { specie { nMoles 1; molWeight 39.948; } thermodynamics { Cp 520; Hf 30; } transport { As 2.054e-06; Ts 162.4; } } p : dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101; boundaryField { inlet { type fixedValue; value uniform 271724; } outlet { type waveTransmissive; field p; phi phi; rho rho; psi psi; fieldInf 101; gamma 1.67; lInf 0.025; value uniform 101; } freestream { type totalPressure; value uniform 101; p0 uniform 101; U U; phi phi; rho none; psi psi; gamma 1.67; } freestreamInlet { type zeroGradient; } wedge1 {type wedge;} wedge2 {type wedge;} } T : dimensions [0 0 0 1 0 0 0]; internalField uniform 98.0; boundaryField { inlet { type fixedValue; value uniform 299.1; } outlet { type zeroGradient; } freestream { type totalTemperature; value uniform 97; T0 uniform 97; U U; phi phi; rho none; psi psi; gamma 1.67; } freestreamInlet { type fixedValue; value uniform 97.0; } wedge1 {type wedge;} wedge2 {type wedge;} } U : dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (515.6 0 0); } outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } freestream { type zeroGradient; } freestreamInlet { type fixedValue; value uniform (0 0 0); } wedge1 {type wedge;} wedge2 {type wedge;} } |
Extremely high Temperature needed to simulate pressurization with rhoCentralFoam | shangzung | OpenFOAM Running, Solving & CFD | 0 | August 6, 2010 06:35 |
Tutorial problem: "rhopSonicFoam - shockTube" with high pressure | shangzung | OpenFOAM | 0 | November 1, 2009 13:07 |
high pressure simulation | mahi | FLUENT | 0 | November 7, 2008 01:30 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 11:26 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
