rhocentralFoam error while modelling hypersonic flow
Old   June 20, 2012, 07:05
Default rhocentralFoam error while modelling hypersonic flow
Nathan Donaldson
Nathan_Donaldson is on a distinguished road
Hello all,
I'm a newcomer to OpenFOAM and am trying to model a hypersonic calibration model using rhoCentralFoam. After completing the Wedge15Ma5 and motorBike tutorials, I successfully created a mesh of my geometry using snappyHexMesh.
The problem I'm having is that whenever I run the case and post-process it, the results (velocity, temperature and pressure) are all completely uniform. checkMesh returns no errors, and I've used a very small time step (0.001). Also, the mean and maximum Courant numbers remain constant between iterations, and the residuals prefixed with 'rho' are perpetually 0.
The freestream boundary conditions I've tried to code are:
Mach number = 17.8
Pressure = 29.5 Pa
Temperature = 287K
I've pasted in the Ma, p, U, T and blockMeshDict files below. Are there any errors that are immediately obvious? I'm sure it'll be something basic that I'm missing.
Many thanks,
Nathan
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      Ma;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 17.8;
boundaryField
    frontAndBack
        type            symmetryPlane;
    outlet
        type            calculated;
        value           uniform 17.8;
    inlet
        type            calculated;
        value           uniform 17.8;
    lowerAndUpperWall
        type            symmetryPlane;
    "HB2.*"
        type            calculated;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 29.5;
boundaryField
    frontAndBack
        type            symmetryPlane;
    inlet
        type            zeroGradient;
        value           uniform 29.5;
    outlet
        type            zeroGradient;
        value           uniform 29.5;
    lowerAndUpperWall
        type            symmetryPlane;
    "HB2.*"
        type            zeroGradient;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 287;
boundaryField
    frontAndBack
        type            symmetryPlane;
    inlet
        type            fixedValue;
        value           uniform 287;
    outlet
        type            inletOutlet;
        inletValue      uniform 287;
        value           uniform 287;
    lowerAndUpperWall
        type            symmetryPlane;
    "HB2.*"
        type            zeroGradient;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (17.8 0 0);
boundaryField
    frontAndBack
        type            symmetryPlane;
    inlet
        type            fixedValue;
        value           uniform (17.8 0 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (17.8 0 0);
    lowerAndUpperWall
        type            symmetryPlane;
    "HB2.*"
        type            zeroGradient;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (-100 -50 -50)
    (-100 50 -50)
    (-100 50 50)
    (-100 -50 50)
    (400 -50 -50)
    (400 50 -50)
    (400 50 50)
    (400 -50 50)
blocks
    hex (0 1 2 3 4 5 6 7) (10 10 50) simpleGrading (1 1 1)
edges
boundary
    frontAndBack
        type symmetryPlane;
        faces
            (2 3 7 6)
            (0 1 5 4)
    inlet
        type patch;
        faces
            (0 3 2 1)
    outlet
        type patch;
        faces
            (4 5 6 7)
    lowerAndUpperWall
        type symmetryPlane;
        faces
            (0 4 7 3)
            (1 2 6 5)
Nathan_Donaldson is offline   Reply With Quote
hypersonic, openfoam 2.0.1, rhocentralfoam
Solver for hypersonic flow in OpenFoam Santos-Dumont OpenFOAM Running, Solving & CFD 19 October 21, 2012 01:42
rhocentralFoam error while modelling hypersonic flow Nathan_Donaldson OpenFOAM 0 June 19, 2012 11:33
modelling slug flow with pressure inlet Azman FLUENT 0 May 29, 2006 06:45
modelling laminar and turbulent flow in the same Ol FLUENT 2 November 25, 2005 02:52
modelling flow in microchannel Wang FLUENT 6 October 10, 2000 09:28
