timeVaryingMappedFixedValue boundary condition in parallel
Old   August 19, 2009, 12:54
Default timeVaryingMappedFixedValue boundary condition in parallel
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello World.
I was not able to decompose a case which used the timeVaryingMappedFixedValue boundary condition!
Does anybody know if it's possible to use this boundary condition in parallel?
sega
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   August 19, 2009, 13:15
Henrik Rusche
henrik is on a distinguished road
Dear Sebastian,
it should work out of the box. There will be triangulated surfaces on every processor. But that's not something to worry about.
Henrik
henrik is offline   Reply With Quote
Old   August 20, 2009, 04:06
sega's Avatar
Sebastian Gatzka
Thank you Henrik.
But I was not able to do so.
I got a segmentation fault when running the decomposer.
Is there some trick involved?
Old   August 25, 2009, 10:30
sega's Avatar
Sebastian Gatzka
I want to get back to my problem with decomposing a case with timeVaryingMappedFixedValue boundary conditions.
I got this message when running decomposePar
sega@deepblue:~/OpenFOAM/sega-1.5/run/arcSmall0$ decomposePar
|  \\    /   O peration     | Version:  1.5                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
Exec   : decomposePar
Date   : Aug 25 2009
Time   : 16:22:49
Host   : deepblue
PID    : 4859
Case   : /home/sega/OpenFOAM/sega-1.5/run/arcSmall0
nProcs : 1
Create time
Time = 0
Create mesh
Calculating distribution of cells
Selecting decompositionMethod simple
Finished decomposition in 0.03 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Calculating processor boundary addressing
Distributing points to processors
Constructing processor meshes
Processor 0
    Number of cells = 4000
    Number of faces shared with processor 1 = 200
    Number of processor patches = 1
    Number of processor faces = 200
    Number of boundary faces = 1400
Processor 1
    Number of faces shared with processor 0 = 200
Max number of processor patches = 1
Max number of faces between processors = 200
#0  Foam::error::printStack(Foam::Ostream&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::sigSegv::sigSegvHandler(int) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  ?? in "/lib/libc.so.6"
#3  vbedg(double, double, int, double*, int, int*, int*, int*, int*, int*, int*) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so"
#4  dtris2(int, double*, int*, int*, int*) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so"
#5  Foam::triSurfaceTools::delaunay2D(Foam::List<Foam::Vector2D<double> > const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libmeshTools.so"
#6  Foam::timeVaryingMappedFixedValueFvPatchField<double>::readSamplePoints() in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#7  Foam::timeVaryingMappedFixedValueFvPatchField<double>::checkTable() in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#8  Foam::timeVaryingMappedFixedValueFvPatchField<double>::updateCoeffs() in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#9  Foam::timeVaryingMappedFixedValueFvPatchField<double>::timeVaryingMappedFixedValueFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#10  Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::timeVaryingMappedFixedValueFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so"
#11  Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#12  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#13  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readField(Foam::Istream&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#14  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#15  void Foam::readFields<domainDecomposition, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >(domainDecomposition const&, Foam::IOobjectList const&, Foam::PtrList<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&) in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#16  main in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
#17  __libc_start_main in "/lib/libc.so.6"
#18  Foam::fvMesh::readUpdate() in "/home/sega/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/decomposePar"
Segmentation fault
I can't tell whats wrong in this case.
Please feel free to have a look at the case itself: http://therealsega.th.funpic.de/open...cSmall0.tar.gz
If you are talking about triangulation ... Do I have to switch one anything for it to work?!
All I was doing was collecting the necessary data for the boundary condition and setting them like this:
    f0
        type            timeVaryingMappedFixedValue;
        setAverage    off;
So, where may be the fault?!
Old   August 27, 2009, 17:29
Mattijs Janssens
mattijs is on a distinguished road
icoFoam does not run with your point set either. Seems your pointset makes the triangulation routine fall over. Set the debug flag timeVaryingMappedFixedValue to 1 in the etc/controlDict. It will output a triangulation.stl which you can load into paraview for checking.
mattijs is offline   Reply With Quote
Old   August 28, 2009, 03:17
sega's Avatar
Sebastian Gatzka
I could narrow the problem down and have taken my questions concerning it to an other thread. Have a look:
http://www.cfd-online.com/Forums/ope...ixedvalue.html
(or maybe http://www.cfd-online.com/Forums/ope...tal-error.html)
Old   June 25, 2012, 09:51
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Hello Sebastian
I have a Seg Fault (fp) error in running a case in parallel that has a timeVarryingMapped BC that is divided. So I think it may be the cause of the error ... so how is your status on the topic???
Best regards
Hisham
Hisham is offline   Reply With Quote
parallel, timevaryingmapped
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
Help Urgent about changing boundary condition Anjum Naveed FLUENT 7 August 14, 2006 12:25
1 and 2 Order Boundary condition at the same place CFD_Flo Main CFD Forum 4 July 11, 2005 11:57
How to resolve boundary condition problem? sam FLUENT 2 July 20, 2003 02:19
