interFoam and static pressure
Like Tree1Likes
  • 1 Post By David*
Old   July 11, 2012, 13:56
Default interFoam and static pressure
Matthias P
MatP is on a distinguished road
Actually i'm solving two phase flows in a single rotating cylinder with a modified version of interFoam which includes the centrifugal forces.
The problem occuring to me at the moment is the thing about the p_rgh field. I've already read the several posts in the forum and i agree with the states, that p_rgh is a modified pressure field created for more computational stability.
But how can i get the static pressure? Because when i compare my results of p with the static pressure calculated with fluent, the results aren't equal.
Can anyone help me with this problem?
MatP is offline   Reply With Quote
Old   July 15, 2012, 11:35
David GISEN
David* is on a distinguished road
Maybe this post helps you: http://www.cfd-online.com/Forums/ope...tml#post285912
And be aware that in incompressible solvers you have to multiply some results by local density to obtain "real" values.
Regards
mizzou likes this.
David* is offline   Reply With Quote
static pressure BC for interFoam kwardle OpenFOAM 2 March 4, 2015 04:29
Slug Flow, interFoam, problems with Contact Angle PrzemekPL OpenFOAM Running, Solving & CFD 13 February 18, 2014 22:10
strange curvature with interFoam (comparison with Brackbill work) duongquaphim OpenFOAM Running, Solving & CFD 23 July 25, 2013 01:03
Pressure problems in restarting santiagomarquezd OpenFOAM Running, Solving & CFD 1 January 5, 2011 22:17
Static Pressure BC in rasInterFoam kwardle OpenFOAM Running, Solving & CFD 0 September 19, 2008 16:15
