Solving for two phase, incompressible, inviscid flow (OpenFOAM)
Old   June 14, 2012, 22:27
Default Solving for two phase, incompressible, inviscid flow (OpenFOAM)
Betsy Seiffert
Betsy is on a distinguished road
Hello - I would like to solve for incompressible, inviscid flow (Euler Equations) for two phases (waves, NOT bubbles) in OpenFOAM. I am considering 3 options and I could use some advice on which may produce the best results or what problems I may run into:
1) Simply use interFoam and set viscosity to approximately zero (i.e. 1E-10 or something like this)
2) Write a new solver based on interFoam removing the viscous term in the Navier-Stokes equation
3) Use twoPhaseEulerFoam - although I am reluctant to use this solver since it is more difficult for me to see exactly how the solver is working and it seems to be geared more towards bubbles.
Any advice is appreciated.
Sincerely,
Betsy
Betsy is offline   Reply With Quote
Old   June 15, 2012, 18:32
Betsy Seiffert
As a follow up - does OpenFOAM use Reynolds number to non-dimensionalize the equation? If so, then this would cause problems with setting viscosity to approx. zero.
Old   June 16, 2012, 06:58
akidess's Avatar
Anton Kidess
No, OpenFOAM works with the dimensional equation. Keep in mind that setting the viscosity to zero or something very small will make the problem "stiff", i.e. make it tougher to obtain a stable numerical solution.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   June 18, 2012, 17:06
Rob
robbirobocop is on a distinguished road
I would use interFoam. I have already seen some bachelor/master thesis that successfully simulated waves (i.e. at/around ships).
However writing your own solver might not be such a problem as well, the wiki gives some good hints on how to modify and expand solvers...
robbirobocop is offline   Reply With Quote
Old   June 27, 2012, 16:08
Ralph Moolenaar
Ralph M is on a distinguished road
Depending on which kind of waves you want to simulate I'd suggest you to have a look into the LTSInterFoam solver which would be of use for semi-static problems.
CFD for marine applications? Go to http://www.marinecfd.com/ and join the OF Ship Hydromechanics Group: http://www.cfd-online.com/Forums/gro...mechanics.html
Ralph M is offline   Reply With Quote
Old   July 15, 2012, 01:52
Ehsan
ehsan is on a distinguished road
Dear All,
Please see Eq. 4 in the paper below:
http://www.marinepropulsors.com/proc...0Propulsor.pdf
May I ask you whether in OpenFOAM the same equation including turbulence effects are used for viscosity of two phase flow or only simple averaging from laminar values are employed?
Thanks
ehsan is offline   Reply With Quote
Old   July 16, 2012, 05:58
Pablo
pablodecastillo is on a distinguished road
Hi Betsy,
Just remove the viscous terms from interFoam, and it is going to work pretty well.
pablodecastillo is offline   Reply With Quote
euler equations, incompressible flows, inviscid flow, two phase
Forces in OF15 richard OpenFOAM Running, Solving & CFD 180 July 9, 2018 10:54
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
ForcesCoeffs ronaldo OpenFOAM 4 September 14, 2009 07:11
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
